I have a concern about using SSL on vesta CP.
When I add 5 SSL on several domains with the same user, I get a 400 or 429 error (It seems that you can’t add too much SSL?) : error let’s encrypt new auth status 429 vestacp.
How can I fix the problem?
Thank you for your feedback
