Problem renewing
My domain is: t7.vc
I ran this command: certbot renew (and others like it like trying to specify a webroot)
It produced this output: C:\windows\system32>certbot renew
Saving debug log to C:\Certbot\log\letsencrypt.log
Processing C:\Certbot\renewal\leat.xyz.conf
Renewing an existing certificate for leat.xyz and 3 more domains
Failed to renew certificate leat.xyz with error: Missing command line flag or config entry for this setting:
Input the webroot for leat.xyz:
C:\Certbot\live\leat.xyz\fullchain.pem (failure)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
My web server is (include version): nodejs
The operating system my web server runs on is (include version): windows 10
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.24.0
Did you do this?
certbot renew --cert-name leat.xyz -w /path/to/webroot
Please show:
Did you modify that file at any point?
When using nodejs the (-w webroot) is just where the server script resides? I tried:
certbot -v renew --cert-name leat.xyz -w D:\Server
Certificate is due for renewal, auto-renewing...
http-01 challenge for leat.xyz
http-01 challenge for t7.vc
http-01 challenge for www.leat.xyz
http-01 challenge for www.t7.vc
Using the webroot path D:\Server for all unmatched domains.
Encountered exception during recovery: FileNotFoundError: [WinError 3] The system cannot find the path specified: 'D:\Server\.well-known\acme-challenge\wy9fp5Qns46m3B-Jo3B8vBUMAfmC87jvD_Z1EMnx2tw'
Failed to renew certificate leat.xyz with error: (1307, 'SetFileSecurity', 'This security ID may not be assigned as the owner of this object.')
No, I went in and looked at it is all.
No idea if nodejs even has the concept of a webroot. How did you get the certificate the first time?
I will repeat myself [only once]:
version = 1.24.0
archive_dir = C:\Certbot\archive\leat.xyz
cert = C:\Certbot\live\leat.xyz\cert.pem
privkey = C:\Certbot\live\leat.xyz\privkey.pem
chain = C:\Certbot\live\leat.xyz\chain.pem
fullchain = C:\Certbot\live\leat.xyz\fullchain.pem
[renewalparams]
account = dbfa6939cc229632eaf998906c089039
authenticator = webroot
I see:
But it seems to be missing the webroot directory path.
Yeah I think I'm going to end up having to make a new one as it expires in a few days and I can't figure that part out.
What is the webroot path for that site?
It seems to be trying: D:\Server
That is where the the server resides yes. But there is no .well-known directory maybe I deleted it on accident?
Try recreating the challenge path and add a test file there:
mkdir D:\Server\.well-known
mkdir D:\Server\.well-known\acme-challenge
echo "test-file-1234" > D:\Server\.well-known\acme-challenge\Test_File-1234
Then we can try accessing it from the Internet:
http://leat.xyz/.well-known/acme-challenge/Test_File-1234
Done. But I don't have that path available in my nodejs sever code and so I get "Cannot GET /.well-known/acme-challenge/Test_File-1234" should I make that path public?
It sounds like it should be made public [via HTTP].
Done I think its public now. -> http://leat.xyz/.well-known/acme-challenge/Test_File-1234
I get:
curl http://leat.xyz/.well-known/acme-challenge/Test_File-1234
Found. Redirecting to https://leat.xyz/.well-known/acme-challenge/Test_File-1234
ACME challenge request don't need to be secure - no need to redirect them to HTTPS.
And the https redirection returns nothing.
Hmm odd. I removed the redirect of http to https and tested the link on my cell data and it is working now I hope. When you say "ACME challenge request don't need to be secure" do you mean they cannot be or just don't need to be. Thank you for all this help btw!
The HTTP challenges are made to HTTP so should be handled there. There is no need to redirect them to HTTPS although as long as your HTTPS is setup properly it will work. Details about redirects are here:
Thanks again, after I set that up I was able to renew the certs with
certbot renew --webroot -w D:\Server\
