Problem renewing LetsEncrypt Certificate
I am facing a problem renewing the certificate on my webserver. Last renewal was on 15/2/2024 and current certificate is valid until 19/5/2024. During last renewal attempt on 15/4/2024 I am getting the following error:
Failed to renew certificate www.protodikeio-thes.gr with error: HTTPSConnectionP ool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with ur l: /directory (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE _VERIFY_FAILED] certificate verify failed: unable to get local issuer certificat e (_ssl.c:1131)')))
Details of the web server
OS Centos 7
Apache 2.4.6
Certbot 2.10.0
openssl 1.0.2
Output of commands:
certbot certficates
Found the following certs:
  Certificate Name: www.protodikeio-thes.gr
    Serial Number: 3f5fe4396c63b70452c94486b228fdc10c1
    Key Type: RSA
    Domains: www.protodikeio-thes.gr
    Expiry Date: 2024-05-19 08:00:54+00:00 (VALID: 19 days)
    Certificate Path: /etc/letsencrypt/live/www.protodikeio-thes.gr/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/www.protodikeio-thes.gr/privkey.pem
echo | openssl s_client -connect acme-v02.api.letsencrypt.org:443 | head
depth=1 DC = local, DC = gov, DC = ddt, CN = ddt-DC1ADCCAV01-SubCA
verify error:num=20:unable to get local issuer certificate
CONNECTED(00000003)
DONE
Certificate chain
0 s:/CN=acme-v02.api.letsencrypt.org
i:/DC=local/DC=gov/DC=ddt/CN=ddt-DC1ADCCAV01-SubCA
1 s:/DC=local/DC=gov/DC=ddt/CN=ddt-DC1ADCCAV01-SubCA
i:/CN=DC1ADPKIP01-Root-CA
Server certificate
-----BEGIN CERTIFICATE-----
curl -Ik https://acme-v02.api.letsencrypt.org/directory
HTTP/1.1 200 OK
Server: nginx
Date: Tue, 30 Apr 2024 05:00:50 GMT
Replay-Nonce: Y_7AIQuU-MLSKvNuM6V8BRZIR5Zmzb4-WO5WmR9J81d4VnqEO0Q
X-Frame-Options: DENY
Content-Length: 747
Via: 1.1 DC1EK-VISRVWSA-05.ddt.gov.local:80 (Cisco-WSA/14.0.3-014)
The only thing that has changed since last successful renewal in February is WAN configuration where a peripheral security has been employed. However I applied for security removal from certain IP's (web server's including) so no ports are blocked. I am not sure if this has been done properly.
Can you check from all the above info if this is a communication error (firewall block) so I can chase it further with my provider otherwise to look locally in the server to resolve the issue.
Any help on that issue will be highly appreciated.
Thank you
you saw a some goverment internal CA certificate on that s_client, so you got intercpeted by that new security.
