Problem in running ./letsencrypt-auto certonly command
Hi
I want to use letsencrypt
and I raun the command ./letsencrypt-auto certonly … command but at the end I give this error:
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
what should I do??
Did you see the error as reported in https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment ?
Thanks
I will check it
