Certbot-auto, letsencrypt-auto has insecure permissions
ylamaa-tasoapp.fi
sudo letsencrypt-auto renew
./letsencrypt-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
Upgrading certbot-auto 0.34.1 to 0.34.2…
Replacing certbot-auto…
Creating virtual environment…
File “/usr/lib/python3/dist-packages/virtualenv.py”, line 2363, in
main()
File “/usr/lib/python3/dist-packages/virtualenv.py”, line 719, in main
symlink=options.symlink)
File “/usr/lib/python3/dist-packages/virtualenv.py”, line 988, in create_environment
download=download,
File “/usr/lib/python3/dist-packages/virtualenv.py”, line 918, in install_wheel
call_subprocess(cmd, show_stdout=False, extra_env=env, stdin=SCRIPT)
File “/usr/lib/python3/dist-packages/virtualenv.py”, line 812, in call_subprocess
% (cmd_desc, proc.returncode))
OSError: Command /opt/eff.org/certbot/venv/bin/python2.7 - setuptools pkg_resources pip wheel failed with error code 1
File “”, line 27, in
File “”, line 19, in create_venv
File “/usr/lib/python2.7/subprocess.py”, line 541, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘[‘virtualenv’, ‘–no-site-packages’, ‘–python’, ‘/usr/bin/python2.7’, ‘/opt/eff.org/certbot/venv’]’ returned non-zero exit status 1
Ububtu LTS 16.04
sudo works
no
assume 0.34.1, if you try to run certbot-auto you will get the error message
Additiional info:
It is a spring boot aplication so I think it is a standalone setup (?). I have not originally set up the application just been updating certificates, until now ut has been working just fine but this time it gives the error, any help would be highly appreciated :slight_smile:
Cheers,
Mika
Have you read the link presented in the error message itself? Certbot-auto deployment best practices
If so, what did you try from those best practices?
I think the insecure permissions is a red herring, the true error is the virtualenv failure.
Unfortunately I don’t know a good way to diagnose it without modifying the script itself to print the stderr of virtualenv (it instead just swallows it).
You could try wipe out /opt/eff.org/certbot, I guess.
thanks for the response.
As I said I have not set this up, jus been updating certs. As of this time it has been working without any problems …
I found this post -> https://medium.com/@jayn0rm/update-letsencrypt-with-certbot-e86736349d2e
Anyhow, thank you for the suggestion, it might be good path to follow, the instance is running on azure cloud
You were right, locales were not set and that caused the error.
export LC_ALL=“en_US.UTF-8”
export LC_CTYPE=“en_US.UTF-8”
after that it went through.
Side note, I had to modify the config file a bit since it had some settings that were outdated.
but after that it worked :slight_smile:
