hi i have a blogger with domain in hostalia.com . my domain is www,chollosparabodas.es
no work my web .
In blogger tall me need add CAA lesencypts.org , but in my panel control hosalia , no have CAA register!
In dns opcion i have A,MX, CNAME,TXT,PTR,SVR,AAAA
my web dont work …
tanhx for helping and sorry my english!
Hi @AntoniAlvz
you don't need a CAA entry. If you don't have a CAA, that's not a problem.
But there is another problem ( https://check-your-website.server-daten.de/?q=chollosparabodas.es ):
Letsencrypt checks if there is a CAA entry. But your server sends a ServerFailure - answer. Not an empty result.
CAA - Entries
| Domainname |
flag |
Name |
Value |
∑ Queries |
∑ Timeout |
| www.chollosparabodas.es |
-2 |
Server failure - The name server was unable to process this query due to a problem with the name server |
4 |
0 |
0 |
no CAA entry found |
1 |
0 |
| ghs.google.com |
0 |
1 |
0 |
| google.com |
5 |
issue |
pki.goog |
1 |
0 |
| com |
0 |
1 |
0 |
| es |
0 |
1 |
0 |
So your nameservers
Domain Nameserver NS-IP
chollosparabodas.es
• dns1.canaldominios.com
82.194.64.50 •
• dns2.canaldominios.com
82.194.64.51 •
• dns3.canaldominios.com
82.194.64.50 •
• dns4.canaldominios.com
82.194.64.51 •
are buggy.
Your non-www uses a Letsencrypt certificate:
CN=chollosparabodas.es (4878)
27.03.2019
25.06.2019
expires in 89 days chollosparabodas.es - 1 entry
And you have an older LE-certificate with the www-version (created 2018-12-27 13:09:57).
So ask your Nameserver provider. They have to update their nameservers.
is work!!! thx men , i have Certificate 26/06/2019 , after this date i need make actions? renove o change new nameservers?
