Fail on CAA record for domain without CAA record
Hi Letsencrypt team -
I’m trying to provision a cert for my home nextcloud (snap) instance at germany.vertesi.com (cname to verthome.tplinkdns.com, dynamic DNS for my home), using the certbot built into nextcloud.
My domain is: germany.vertesi.com
According to https://dnsspy.io/labs/caa-validator I don’t have a CAA record on the child or parent domain, of either domain (germany.vertesi.com or verthome.tplinkdns.com). My domain is hosted on dyn.com, which doesn’t allow me to (easily) set a CAA record. Dig just returns the SOA record.
Thanks in advance for your help!
According to the debug log, I ran certbot with these arguments: [’–text’, ‘–config-dir’, ‘/var/snap/nextcloud/current/certs/certbot/config’, ‘–work-dir’, ‘/var/snap/nextcloud/current/certs/certbot/work’, ‘–logs-dir’, ‘/var/snap/nextcloud/current/certs/certbot/logs’, ‘–authenticator’, ‘nextcloud:webroot’, ‘–nextcloud:webroot-path’, ‘/var/snap/nextcloud/current/certs/certbot’, ‘–rsa-key-size’, ‘4096’, ‘–email’, ‘campbell@vertesi.com’, ‘–non-interactive’, ‘–agree-tos’, ‘–force-renewal’, ‘-d’, ‘germany.vertesi.com’]
http-01 challenge for germany.vertesi.com
Using the webroot path /var/snap/nextcloud/current/certs/certbot for all domains.
Failed authorization procedure. germany.vertesi.com (http-01): urn:ietf:params:acme:error:caa :: CAA record for germany.vertesi.com prevents issuance
   Domain: germany.vertesi.com
   Type:   None
   Detail: CAA record for germany.vertesi.com prevents issuance
My web server is (include version): nextcloud snap’s built-in Apache
The operating system my web server runs on is (include version): Ubuntu 18.04 server LTS
My hosting provider, if applicable, is: Me. :slight_smile:
Updated to use a simple A record, and it works! Did I miss some critical documentation or something? What was wrong with the CNAME?
The problem isn't with Dyn or (directly) with your domain, it's with TP-Link.
The error message is misleading: it happens when you have CAA records explicitly blocking Let's Encrypt, and it can happen when the DNS response is invalid.
When Let's Encrypt's does a DNS query for germany.vertesi.com CAA, the DNS resolver follows the CNAME to verthome.tplinkdns.com and... I'm not sure what happens.
tplinkdns.com has a lot of issues. I'm not even sure what most of them are.
http://dnsviz.net/d/tplinkdns.com/W8w6vA/dnssec/
$ dig verthome.tplinkdns.com caa
;; Got bad packet: FORMERR
67 bytes
88 dc 81 80 00 01 00 01 00 00 00 01 08 76 65 72          .............ver
74 68 6f 6d 65 09 74 70 6c 69 6e 6b 64 6e 73 03          thome.tplinkdns.
63 6f 6d 00 01 01 00 01 c0 0c 01 01 00 01 00 00          com.............
02 6c 00 04 5b 41 76 ba 00 00 29 10 00 00 00 00          .l..[Av...).....
00 00 00                                                 ...
One of them is responding with something invalid to CAA queries.
Another is that they don't support random capitalization, which is not invalid, but which may cause Let's Encrypt's resolvers to fail.
Not really. CNAMEs are okay. You were just using a CNAME to a DNS service that doesn't work well.
Edit:
To be explicit, it's fine not to have CAA records. A valid negative response is a-ok.
Also, I forgot to mention it, but there was one previous thread reporting issues with that domain.
Thank you for the fast, thorough and clear response.
Now I like letsencrypt EVEN MORE. You people are awesome.
