DNS problem: SERVFAIL looking up CAA
My domain is: www.niwdedev.me
sudo certbot -d www.niwdedev.me --manual --preferred-challenges dns certonly
Saving debug log to /var/log/letsencrypt/letencrypt.log
dns-01 challenge for www.niwdedev.me
Please deploy a DNS TXT record under the name _acme-challenge.www.niwdedev.me with the following value:
efG0lQ8k5l9Mm3cqUEhXfDxWnBCo_gL5q9aB_COjAfs
Before continuing, verify the record is deployed.
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. www.niwdedev.me (dns-01): urn:acme:error:dns :: DNS problem: SERVFAIL looking up CAA for niwdedev.me
Domain: www.niwdedev.me
Type: None
Detail: DNS problem: SERVFAIL looking up CAA for niwdedev.me
My web server is (include version): Alicloud ECS
The operating system my web server runs on is (include version): Ubuntu 16.04.6
My hosting provider, if applicable, is: Alicloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.22.2
your site’s DNS just failed. I just can’t connect to your site even by http.
Hi @niwde
there is a check of your domain, ~~4 hours old - https://check-your-website.server-daten.de/?q=niwdedev.me
The name servers are terrible red.
X Fatal error: Nameserver doesn't support TCP connection: ns7.alidns.com: Fatal error (0)
X Fatal error: Nameserver doesn't support TCP connection: ns7.alidns.com / 106.11.141.131: Refused
X Fatal error: Nameserver doesn't support TCP connection: ns7.alidns.com / 106.11.141.141: Refused
X Fatal error: Nameserver doesn't support TCP connection: ns7.alidns.com / 106.11.211.71: Refused
No TCP-connection possible, Refused.
Same with your CAA-Part:
Domainname flag Name Value ∑ Queries ∑ Timeout
www.niwdedev.me 0 no CAA entry found 1 0
niwdedev.me -5 Refused - The name server refuses to perform the specified operation for policy reasons 1 0
Looks like the domain doesn't work.
PS: Curious: Your non-www -> Refused. Your www works and has an ip address.
niwdedev.me Refused yes 1 0
www.niwdedev.me A 47.88.225.244 Singapore//Singapore (SG) - Alibaba.com LLC No Hostname found yes 1 0
AAAA yes
If it is possible (but I don't think), try to create a CAA entry with your www domain name.
If such an entry exists, the non-www CAA isn't checked.
Hi @JuergenAuer, thank you so much for your prompt reply!
Sorry that I am really new to this. (Trying to sort out this server which I just took over from my colleague who just quit)
Adding a CAA record
Type: CAA
Host: _____ .www.niwdedev.me
ISP Line: Default
Value: letsencrypty.org
TTL: 10mins
Can I check what I should be filling in for my Host?
The problem seems to be that the DNS zone is named "www.niwdedev.me" instead of "niwdedev.me". So, for example, http://niwdedev.me/ doesn't resolve because the DNS servers don't think it exists. On the other hand, you created an A record named www in the zone, so http://www.www.niwdedev.me/ does currently exist!
You have to fix it by renaming the zone from "www.niwdedev.me" to "niwdedev.me" in the DNS control panel, if that's possible. If it's not possible, you might have to create a new zone named "niwdedev.me" and copy your records over, and you might have to delete the old one.
For Let's Encrypt, you can work around the problem by creating the CAA record mentioned.
That should be letsencrypt.org -- you added a second y.
The end result is that the record needs to be named www.niwdedev.me. Do you know what you need to enter to produce that? You probably have to leave the host field blank, or write @ or something.
You guys are awesome for replying this fast!
@mnordhoff noted, I will need to check on that record after I get this site authenticated. And kudos for spotting my typo haha.
However, I’m not sure what I’m doing wrong with trying to add the CAA record:
47%20AM
I will check with AliCloud on this CAA record issue and get back! Ty guys!
Do they have any documentation showing how to enter a CAA record?
Don’t set the hsot to “www”. Try leaving it blank or using “@”.
Try setting the value to this:
0 issue "letsencrypt.org"
Instead of just letsencrypt.org.
@JuergenAuer @mnordhoff
    /etc/letsencrypt/live/www.niwdedev.me/fullchain.pem
Thank you guys so much, I got it authenticated now!
@mnordhoff Thank you so much! That allowed me to set the CAA record in AliCloud and authenticate the challenge.
Really appreciate the prompt response and help in this community!! :smile:
That’s great! :smile:
I didn’t explain anything, but a CAA record consists of three fields: Currently, the first one can be 0 or 128; the second one can be iodef, issue or issuewild, and the third one contains the CA or (for iodef records) your contact information.
‘0 issue "letsencrypt.org"’ is the standardized way to represent the CAA record in text, but different DNS interfaces make people enter data in different ways. For example, some might have three separate boxes. If it’s not documented, it can take some guesswork to figure out exactly what’s needed. :slightly_frowning_face:
You should still fix the issue – the name of the zone – that caused this, though. It might cause other problems for you in the future, unrelated to Let’s Encrypt.
Roger that! That would explain some of the other issues i'm facing.... :sweat_smile:
And thank you so much again!!!
