smoki.fish
./letsencrypt-auto certonly -a webroot --webroot-path=/var/www/html --no-bootstrap --no-self-upgrade --agree-tos --non-interactive --renew-by-default -d smoki.fish -d www.smoki.fish
/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/cryptography/hazmat/primitives/constant_time.py:26: CryptographyDeprecationWarning: Support for your Python version is deprecated. The next version of cryptography will remove support. Please upgrade to a 2.7.x release that supports hmac.compare_digest as soon as possible.
utils.DeprecatedIn23,
http-01 challenge for smoki.fish
http-01 challenge for www.smoki.fish
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Challenge failed for domain smoki.fish
Challenge failed for domain www.smoki.fish
Domain: smoki.fish
Type: None
Detail: DNS problem: SERVFAIL looking up CAA for smoki.fish
Domain: www.smoki.fish
Type: None
nginx 1.12.2
Ubuntu 14.04
no
no
$ ./certbot-auto --version
certbot 0.32.0
After turning up debug logging, it seems that the problem is with the signature of your nameservers’ NSEC responses … one workaround could be to add CAA records for smoki.fish and www.smoki.fish to avoid any NSEC …
Following this trick from @mnordhoff to identify that these nameservers are running PowerDNS, if you run the nameservers , you could also try to rehash the zone:
sudo pdnsutil rectify-zone smoki.fish
or if you don’t run the nameservers, you can ask the operator to do the same.
Thank you very much for the answer! We’ll first try to remove all DNSSEC records except one with key id = 6935 which is pointed by DS record as I see here https://mxtoolbox.com/SuperTool.aspx?action=ds%3asmoki.fish&run=toolpage. If it doesn’t solve the problem, we’ll ask the operator to rehash the zone. Thanks a lot! I’ll come back soon.
Fatal error: Nameserver doesn't support TCP connection: demand.alpha.aridns.net.au: Fatal error (-14). Details: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. - An existing connection was forcibly closed by the remote host
Checking a CAA record: First smoki.fish is checked, if there is no CAA entry, fish is checked. So if you have a smoki.fish - CAA, the buggy nameserver is ignored.
