Good morning and hello everyone.
On the domain https://vodmyxx.eu/ I have installed an NGINX server with your certificate via certbot. All worked correctly until the time of the certificate renewal. Now using the certbot renew --dry-run command
from the linux server I get this error: To fix these errors, please make sure that your domain name was
entered correctly and the DNS A / AAAA record (s) for that domain
contain (s) the right IP address.
I state that the configuration of the A / AAA records by me has not been changed.
How can I solve?
Thank you
Posting the full output of the command would help, so that we can see what authenticator plugin you are using.
Does it work with the nginx authenticator?
certbot renew --nginx --dry-run
Processing /etc/letsencrypt/renewal/vodmyxx.eu.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for vodmyxx.eu
Attempting to renew cert (vodmyxx.eu) from /etc/letsencrypt/renewal/vodmyxx.eu.conf produced an unexpected error: Failed authorization procedure. vodmyxx.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://vodmyxx.eu/.well-known/acme-challenge/NEd8CFwRW1dHIv6rBnFFrK_veU6_AQcuqQziJkYiFaM [95.110.129.110]: "\r\n404 Not Found\r\n<body bgcolor="white">\r\n
404 Not Found
\r\n". Skipping.
Processing /etc/letsencrypt/renewal/www.vodmyxx.eu.conf
http-01 challenge for www.vodmyxx.eu
Attempting to renew cert (www.vodmyxx.eu) from /etc/letsencrypt/renewal/www.vodmyxx.eu.conf produced an unexpected error: Failed authorization procedure. www.vodmyxx.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.vodmyxx.eu/.well-known/acme-challenge/r5ap8XSDwJvVX9JaiSAIQd84RiOFRbcgYIQHkP5dnqE [95.110.129.110]: "\r\n404 Not Found\r\n<body bgcolor="white">\r\n
404 Not Found
\r\n". Skipping.
/etc/letsencrypt/live/vodmyxx.eu/fullchain.pem (failure)
/etc/letsencrypt/live/www.vodmyxx.eu/fullchain.pem (failure)
2 renew failure(s), 0 parse failure(s)
Domain: vodmyxx.eu
Detail: Invalid response from
Found\r\n<body bgcolor="white">\r\n404
\r\n
Not Found
"To fix these errors, please make sure that your domain name was
contain(s) the right IP address. -
Domain: www.vodmyxx.eu
\r\n
Not Found
