Renew problem with certbot renew --dry-run
My domain is: jthome.thioulouse.fr
I ran this command: sudo certbot renew --dry-run
Failed to renew certificate jthome.thioulouse.fr with error: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb2fc1d18>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
My web server is (include version): nginx/1.18.0 (Ubuntu)
Ubuntu 21.04 (GNU/Linux 5.11.0-1023-raspi armv7l)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.29.0
Hi @JT69V, and welcome to the LE community forum :slight_smile:
That's a DNS issue.
Please check:
cat /etc/resolv.conf
dig acme-staging-v02.api.letsencrypt.org +short
dig acme-staging-v02.api.letsencrypt.org +short @8.8.8.8
Thanks, it was indeed a DNS problem (unknown problem with systemd-resolved, so I replaced resolv.conf by a static file).
Is there anything else I should do now ?
Processing /etc/letsencrypt/renewal/jthome.thioulouse.fr.conf
Simulating renewal of an existing certificate for jthome.thioulouse.fr
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/jthome.thioulouse.fr/fullchain.pem (success)
Probably do an actual renewal instead of just the --dry-run :wink:
Yes of course, thanks a lot !
:smiley:
