I ran this command: sudo certbot --nginx -d mydomain.com
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/mydomain.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for mydomain.com
Waiting for verification…
Failed authorization procedure. mydomain.com (http-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up A for mydomain.com
Domain: mydomain.com
Type: None
Detail: DNS problem: NXDOMAIN looking up A for
nginx version: nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): ubuntu
My hosting provider, if applicable, is: aws
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
using the certbot cli tool it tells me that my certificate has not expired but when I connect through a browser it says it expired in july. After clearing my local browser cache I am now totally unable to access my site to see if the certificate is even still there. Is there a way to delete my existing certifcate and just get a new one with auto-renew? I think I am experiencing a greater dns error unrelated to let’s encrypt but the inconsistencies with the certificate are making it harder to diagnose. Thank you
