Please Put Technology Stacks in Headers - Makes It Easy to help
Hi All
Just a small suggestion for those posting for help
I have expertise in windows, Java Key Stoes, NGINX, cloudflare and a few other specialised areas
I am generally spending far less time on the community than i used but still would like to share insights when i can
If you can put the tech stacks in the heading it makes it much easier for people to contribute
A heading like 404 errors or lots of lines means nothing (I generally will ignore it)
Error 404 or windows IIS with Certify will be something I would look at :smiley:
Just a small bit of feedback
Andrei
Maybe there could be a scrape for known keywords from all the initial input jargon and ramblings and displayed in an additional field… like “Keywords”
