Hello, i’m trying to create SSL website.
I ran this command: sudo certbot --authenticator webroot --installer apache
Traceback (most recent call last): File "/usr/bin/certbot", line 6, in <module> from pkg_resources import load_entry_point File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3019, in <module> @_call_aside File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3003, in _call_aside f(*args, **kwargs) File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 3032, in _initialize_master_working_set working_set = WorkingSet._build_master() File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 646, in _build_master ws = cls() File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 639, in __init__ self.add_entry(entry) File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 695, in add_entry for dist in find_distributions(entry, True): File "/usr/lib/python2.7/dist-packages/pkg_resources/__init__.py", line 2012, in find_on_path if len(os.listdir(fullpath)) == 0: OSError: [Errno 13] Permission denied: '/usr/lib/python2.7/dist-packages/Flask-0.10.1.egg-info'
My web server is (include version): Raspberry pi 2 model: B
The operating system my web server runs on is (include version): Raspbian GNU/Linux 8
My hosting provider, if applicable, is: I host my website by me.
EDIT: With sudo su
and then certbot --authenticator webroot --installer apache
I get same output
Thanks for help
Dejan
