Error running certbot - Ubuntu 18.04 [solved]
When I run sudo certbot from the command line I get:
$ sudo certbot
An unexpected error occurred:
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 60, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/lib/python3.6/socket.py”, line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 346, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 852, in _validate_conn
conn.connect()
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 284, in connect
conn = self._new_conn()
File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 150, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f836a768eb8>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File “/usr/lib/python3/dist-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘acme-v02.api.letsencrypt.org’, port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x7f836a768eb8>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,))
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘acme-v02.api.letsencrypt.org’, port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x7f836a768eb8>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’,))
Hi @alento
looks like your "server" can't talk with Letsencrypt.
What's your domain name? You need a public visible and unique domain name to get a certificate.
Yeah … looks like the server is not looking up the LE server correctly. When I do a
nslookup acme-v02.api.letsencrypt.org I get a SERVFAIL.
Looks like I need someone to investigate why resolve is not working properly …
I utilized an entry to the /etc/hosts file and was able to renew the certs with no problem.
Change your DNS servers to ones that work.
