Hello,
I am just curious if there is any blog post regarding the ongoing maintenance or if there is an ETA for when it will be complete?
Thanks,
Hello,
Thanks,
Hi!
Thank you for your response. They were using an older LE library, it seems. An update resolved my client's issue, which was (for informational purposes) being reported as follows:
Warning
The current status as reported by the Let's Encrypt status page is Service Disruption as at 2021-04-26 05:38:07.339 +0000 UTC. Depending on the reported problem, this may affect certificate issuance. For more information, please visit the status page.
https://letsencrypt.status.io/
Thanks again!
That was a valid question, though, about where the planned maintenance is announced? https://letsencrypt.status.io says that the service really is down:
The only services that are down are
Normal certificate issuance should work fine, though there do seem to be some ACME clients out there that are "smart" enough to check the status info, but not smart enough to check which services are down, and so are giving their users errors when in fact everything would work if they just tried. But if you're having some specific problem, you should make a thread about the specific problem you're facing, and especially include how you're trying to get the certificate and what error messages you see.
Probably it was this morning's database maintenance. You can subscribe to maintenance notifications via the [Subscribe] button on https://letsencrypt.status.io/, or if you'd rather just monitor @letsencrypt_ops on Twitter you can do that. Status.io posts to Twitter (there), an RSS feed (without filtering, sadly), Slack, and sends emails.
