Obtain first certificate: timeout
My domain is: campo-randale.de
I ran this command: certbot --apache
Domain: crbox.campo-randale.de
Type: connection
Detail: Fetching
http://crbox.campo-randale.de/.well-known/acme-challenge/d2C02-4MXN8jysq6y5WTnMxkghw8fpkGjU8GPK2AC5Y:
(the challenge is faked)
My web server is (include version): Apache2.4
The operating system my web server runs on is (include version): Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.30.2
But the Web-Service is reachable from the internet via port 80. (At least when I try to get the cert :wink: I do not see any FW problems. What can I check next?
Hi @hjfh
is this your domain? If yes, that domain is parked, so you can't create a certificate.
If no, please share your domain name.
? Yes, this is my domain. Why you think it is parked? I can access the host crbox.campo-randale.de via http. But the FW permit https, too. (just in the moment the FW drops the connections)
Checked the main domain, the result is curious ( https://check-your-website.server-daten.de/?q=campo-randale.de ):
• http://campo-randale.de/
217.160.157.99 403 0.057 M
Forbidden
• http://www.campo-randale.de/
217.160.157.99 403 0.053 M
Forbidden
• https://campo-randale.de/
217.160.157.99 -4 0.080 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. The handshake failed due to an unexpected packet format.
• https://www.campo-randale.de/
• http://campo-randale.de:443/
217.160.157.99 403 0.053 Q
Forbidden
Visible Content:
• http://www.campo-randale.de:443/
217.160.157.99 403 0.050 Q
Forbidden
Visible Content:
• http://campo-randale.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
217.160.157.99 300 0.047
Visible Content: Multiple Choices The document name you requested ( /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de ) could not be found on this server. However, we found documents with names similar to the one you requested. Available documents: /./acme-challenge/check-your-website-dot-server-daten-dot-de (common basename) /…/acme-challenge/check-your-website-dot-server-daten-dot-de (common basename)
• http://www.campo-randale.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
217.160.157.99 300 0.044
https has a typical error, so the tool checks http over port 443.
Checked that url manual, there is
<!DOCTYPE html>
<html>
    <head>
        <meta charset="utf-8">
        <style type="text/css">
            html, body, #partner, iframe {
                height:100%;
                width:100%;
                margin:0;
                padding:0;
                border:0;
                outline:0;
                font-size:100%;
                vertical-align:baseline;
                background:transparent;
            body {
                overflow:hidden;
        </style>
        <meta content="NOW" name="expires">
        <meta content="index, follow, all" name="GOOGLEBOT">
        <meta content="index, follow, all" name="robots">
        <!-- Following Meta-Tag fixes scaling-issues on mobile devices -->
        <meta content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" name="viewport">
    </head>
    <body>
        <div id="partner"></div>
        <script type="text/javascript">
            document.write(
                    '<script type="text/javascript" language="JavaScript"'
                            + 'src="//sedoparking.com/frmpark/'
                            + window.location.host + '/'
                            + 'IONOSParkingDE'
                            + '/park.js">'
                    + '<\/script>'
        </script>
    </body>
</html>
a sedoparking included.
And critical: /.well-known/acme-challenge sends a multiple choice, so it looks that you can’t use http-01 validation.
Now checking the subdomain - crbox
Ah, your main domain is hosted via 1&1 ( https://check-your-website.server-daten.de/?q=campo-randale.de ):
campo-randale.de A 217.160.157.99 Karlsruhe/Baden-Württemberg/Germany (DE) - 1&1 Internet SE Hostname: campo-randale.net yes 1 0
AAAA yes
www.campo-randale.de A 217.160.157.99 Karlsruhe/Baden-Württemberg/Germany (DE) - 1&1 Internet SE Hostname: campo-randale.net yes 1 0
AAAA yes
Your subdomain - looks like a home server ( https://check-your-website.server-daten.de/?q=crbox.campo-randale.de ):
crbox.campo-randale.de A 195.145.32.219 Gelnhausen/Hesse/Germany (DE) - Deutsche Telekom AG No Hostname found yes 1 0
AAAA yes
www.crbox.campo-randale.de Name Error yes 1 0
And there are only timeouts:
• http://crbox.campo-randale.de/
195.145.32.219 -14 10.026 T
Timeout - The operation has timed out
• https://crbox.campo-randale.de/
• http://crbox.campo-randale.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
195.145.32.219 -14 10.030 T
Visible Content:
If you see the subdomain internal, your http works.
Port forwarding correct? Extern port 80 -> intern port 80.
Firewall?
A working port 80 is required to use http-01 validation.
Yes, when I enable the redirection I can access the website from the internet. I is enabled now.
Are there special hints to do when the site is hosted as a vhost in apache?
Yep, now your port 80 works:
195.145.32.219 200 0.054 H
195.145.32.219 -4 0.094 W
• http://crbox.campo-randale.de:443/
195.145.32.219 403 0.054 Q
Forbidden
Visible Content: Access forbidden! You don't have permission to access the requested directory. There is either no index document or the directory is read-protected. If you think this is a server error, please contact the webmaster . Error 403 crbox.campo-randale.de Apache
195.145.32.219 404 0.053 A
Not Found
That's the expected result: Port 80 is open and answers with the http status 404 - Not Found checking a file in /.well-known/acme-challenge.
So http-validation should work.
Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks that file.
Fine ... now you found what I try to described: Web-service ist running but cerbot failed ...
Should the file in acme-challenge stay if the certbot throws the reported error message? There is no .well-known directory at my host ...
Then your configuration may be buggy.
What says
apachectl -S
VirtualHost configuration:
192.168.252.148:80 crbox.campo-randale.de (/etc/apache2/vhosts.d/crbox_campo-randale_de.conf:13)
ServerRoot: “/srv/www”
Main DocumentRoot: “/srv/www/htdocs”
Main ErrorLog: “/var/log/apache2/error_log”
Mutex default: dir="/run/" mechanism=default
PidFile: “/var/run/httpd.pid”
Define: SYSCONFIG
Define: SSL
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“wwwrun” id=473
Group: name=“www” id=476
What's the content of
Is there a DocumentRoot (without any additional location definitions)? If yes, use --webroot instead of --apache.
certbot run -a webroot -i apache -w yourDocumentRoot -d crbox.campo-randale.de
Indeed there is a DocumentRoot for this vhost. But the comment line:
certbot -i apache -w /srv/www/htdocs/vhosts/crbox_campo-randale_de/nextcloud -d crbox.campo-randale.de give the same result...
There is no -a webroot parameter, so it's the same command as --apache.
Sorry typo,
has to be:
certbot run -a webroot -i apache -w …
(No copy &Paste at this terminal :wink:
Then this
is wrong.
Create the two subdirectories
/srv/www/htdocs/vhosts/crbox_campo-randale_de/nextcloud/.well-known/acme-challenge
there a file (file name 1234), then try to load that file via
http://crbox.campo-randale.de/.well-known/acme-challenge/1234
And share the content of the config file.
The file 1234 is then readable via Browser. (Hm, I have to stop access to the file system via apache later …)
Wich config file did you point? vhost?
The content of that file.
Your /1234 file works, so webroot should work.
This is the result :-\
certbot run -a webroot -i apache -w /srv/www/htdocs/vhosts/crbox_campo-randale_de/nextcloud/ -d crbox.campo-randale.de
Plugins selected: Authenticator webroot, Installer apache
http-01 challenge for crbox.campo-randale.de
Using the webroot path /srv/www/htdocs/vhosts/crbox_campo-randale_de/nextcloud for all unmatched domains.
Failed authorization procedure. crbox.campo-randale.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://crbox.campo-randale.de/.well-known/acme-challenge/k57egdNMux2iLORNvVLbyE1Rmq46aGD-FuOnagvCDOU: Timeout during connect (likely firewall problem)
    Type: connection
    Detail: Fetching
the vhost.conf is available at the web http://crbox.campo-randale.de/crbox_campo-randale_de.conf
Your server is online - https://check-your-website.server-daten.de/?q=crbox.campo-randale.de - why sees Letsencrypt a timeout?
Is there a blocking firewall with regional settings? So the online tool can see your site, Letsencrypt not?
Oops … :worried:
Indeed, I have some filtered regions … But I have never seen a problem with it …
OK, wich IPs are neccessary to play with letsencrypt?
