Certbot report possible firewall rule issue (--expand)
mll7.com
mserv.pw
mserv.top
certbot certonly --expand --rsa-key-size=4096 -n --webroot -w /var/www/html/www -d mll7.com --webroot -w /var/www/html/www -d www.mll7.com --webroot -w /var/www/html/www -d vpn.mll7.com --webroot -w /var/www/html/www -d mail.mll7.com --webroot -w /var/www/html/www -d meet.mll7.com --webroot -w /var/www/html/www -d jonathanfalk.mll7.com --webroot -w /var/www/html/www -d mserv.pw --webroot -w /var/www/html/www -d www.mserv.pw --webroot -w /var/www/html/www -d vpn.mserv.pw --webroot -w /var/www/html/www -d mail.mserv.pw --webroot -w /var/www/html/www -d meet.mserv.pw --webroot -w /var/www/html/www -d jonathanfalk.mserv.pw --webroot -w /var/www/html/www -d mserv.top --webroot -w /var/www/html/www -d www.mserv.top --webroot -w /var/www/html/www -d vpn.mserv.top --webroot -w /var/www/html/www -d mail.mserv.top --webroot -w /var/www/html/www -d meet.mserv.top --webroot -w /var/www/html/www -d jonathanfalk.mserv.top
http-01 challenge for jonathanfalk.mll7.com
http-01 challenge for meet.mll7.com
http-01 challenge for mll7.com
http-01 challenge for vpn.mll7.com
http-01 challenge for www.mll7.com
Using the webroot path /var/www/html/www for all unmatched domains.
Challenge failed for domain jonathanfalk.mll7.com
Challenge failed for domain meet.mll7.com
Challenge failed for domain mll7.com
Challenge failed for domain vpn.mll7.com
Challenge failed for domain www.mll7.com
apache2 2.4.41-4ubuntu3.1
nginx-full 1.18.0-0ubuntu1.2
Ubuntu 20.04.2 LTS
N/A
Yes
No
certbot 0.40.0
cat /var/log/apache2/access.log | grep "www.letsencrypt.org" | grep "03/Jun/2021:19:28"
3.142.122.14 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/Na90W3C9ZWtHQyAGHD5iVO5REumS4tKfOPMWh4YvW74 HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.142.122.14 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/qzWsnYCmiXFXz_JiRSX9U9CxN-mQUkKNW0vX5e-F_eo HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
18.184.114.154 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/qzWsnYCmiXFXz_JiRSX9U9CxN-mQUkKNW0vX5e-F_eo HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.19.56.43 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/JQdXR10eVA_z4qrZvjsMA4x6iLev2qV5kDUB40bJk-Q HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
34.221.255.206 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/Na90W3C9ZWtHQyAGHD5iVO5REumS4tKfOPMWh4YvW74 HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
54.189.22.122 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/qzWsnYCmiXFXz_JiRSX9U9CxN-mQUkKNW0vX5e-F_eo HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.120.130.29 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/Na90W3C9ZWtHQyAGHD5iVO5REumS4tKfOPMWh4YvW74 HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
52.39.4.59 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/JQdXR10eVA_z4qrZvjsMA4x6iLev2qV5kDUB40bJk-Q HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
18.116.86.117 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/bYkw8xdMgX9_7ToySwQbycEt3hF04pB78iZtoRsuGcE HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
52.39.4.59 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/bYkw8xdMgX9_7ToySwQbycEt3hF04pB78iZtoRsuGcE HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.122.178.200 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/JQdXR10eVA_z4qrZvjsMA4x6iLev2qV5kDUB40bJk-Q HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.19.56.43 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/SFA_SDf478fwPn7XqRQmHVj72-Pdbar6lg4cTh0vXNQ HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
3.120.130.29 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/bYkw8xdMgX9_7ToySwQbycEt3hF04pB78iZtoRsuGcE HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
52.39.4.59 - - [03/Jun/2021:19:28:19 -0500] "GET /.well-known/acme-challenge/SFA_SDf478fwPn7XqRQmHVj72-Pdbar6lg4cTh0vXNQ HTTP/1.1" 200 336 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
curl http://jonathanfalk.mll7.com/.well-known/acme-challenge/qzWsnYCmiXFXz_JiRSX9U9CxN-mQUkKNW0vX5e-F_eo
qzWsnYCmiXFXz_JiRSX9U9CxN-mQUkKNW0vX5e-F_eo.NjVU1ttmm7KWthKactl13VRE-23Jdwc2sdvQK_XlGS4
Let me know if you want the letsencrypt.log file as it is too long to paste here...
Let's Encrypt can connect to other Vultr servers in that IP range, so it seems likely that it is actually a firewall issue on your server.
Do you have any IPs blocked in iptables? What's the output of:
sudo iptables-save
Sometimes software like fail2ban or similar can trigger these blocks.
It can be slightly misleading to read the logs because Let's Encrypt makes requests from multiple validation servers at once.
I notice that 66.133.109.36 is missing from your logs, which is one of the currently active validation IPs. Worth checking in your iptables for that.
Keep in mind that Let's Encrypt does not publish its validation IPs and that they do change.
Thanks for prompt followup.
Here is the output from iptables-save
iptables-save
Generated by iptables-save v1.8.4 on Thu Jun 3 20:56:16 2021
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [41:3660]
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -i lo -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -m state --state NEW -m recent --set --name DEFAULT --mask 255.255.255.255 --rsource
-A INPUT -p tcp -m tcp --dport 22 -m state --state NEW -m recent --update --seconds 60 --hitcount 10 --name DEFAULT --mask 255.255.255.255 --rsource -j DROP
-A INPUT -p tcp -m state --state NEW -m tcp --dport 22 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --dport 80 -j ACCEPT
-A INPUT -p tcp -m state --state NEW -m tcp --dport 443 -j ACCEPT
-A INPUT -p tcp -m state --state NEW,ESTABLISHED -m tcp --dport 21 -j ACCEPT
-A INPUT -p tcp -m state --state RELATED,ESTABLISHED -m tcp --dport 15000:15100 -j ACCEPT
-A INPUT -s 192.168.12.6/32 -p tcp -m multiport --dports 111,2049 -j ACCEPT
-A INPUT -j DROP
-A FORWARD -j REJECT --reject-with icmp-host-prohibited
-A FORWARD -j DROP
COMMIT
Completed on Thu Jun 3 20:56:16 2021
And regarding the 66.133.109.36, it had been flagged by HostsDeny so cleared that one.
That seems to have done the trick, because I no longer see the timeout for your domain:
Simulating a certificate request for jonathanfalk.mll7.com
  Domain: jonathanfalk.mll7.com
  Type:   unauthorized
  Detail: Invalid response from https://jonathanfalk.mll7.com/.well-known/acme-challenge/S-Nk579Rbx77s4a83kIdjc-0zxFBj1oeIjCfOuuz8fY [45.32.211.10]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
Great, thanks! Tried again with dry run this time and it was successful so ran a production which failed:
Dry run
http-01 challenge for jonathanfalk.mserv.pw
http-01 challenge for jonathanfalk.mserv.top
http-01 challenge for meet.mserv.pw
http-01 challenge for meet.mserv.top
http-01 challenge for mserv.pw
http-01 challenge for mserv.top
http-01 challenge for vpn.mserv.pw
http-01 challenge for vpn.mserv.top
http-01 challenge for www.mserv.pw
http-01 challenge for www.mserv.top
http-01 challenge for mail.mll7.com
http-01 challenge for mail.mserv.pw
http-01 challenge for mail.mserv.top
  • The dry run was successful.
Production
Ran one more time and this time it worked:
    /etc/letsencrypt/live/mserv.pw/fullchain.pem
    /etc/letsencrypt/live/mserv.pw/privkey.pem
    Your cert will expire on 2021-09-02. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    "certbot renew"
    Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Whatever was different this time made it successful - thanks a lot for helping troubleshooting this!
