Hello guys, I have problem to generate new certs. The port 80 and 443 is forwarded from router to virtual machine the default page of Apache is opening in browser and after openinig /.well-known/acme-challenge URL I see files. But when i am trying generate certs for site i am getting error Timeout during connect (likely firewall problem).
I tryed standalone, webroot and apache options and no luck.
smart.nysa.eu
certbot certonly --test-cert -d smart.nysa.eu --apache --preferred-challenges http --debug-challenges -v
Apache 2.4.29
Ubuntu 18.04 LTS
YES
NO
certbot 0.31.0
Log file:
Root logging level set at 10
Requested authenticator webroot and installer None
Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
Initialized: <certbot.plugins.webroot.Authenticator object at 0x7efec0e55b00>
Prep: True
Selected authenticator <certbot.plugins.webroot.Authenticator object at 0x7efec0e55b00> and installer None
Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-staging-v02.api.letsencrypt.org/acme/acct/15002956', new_authzr_uri=None, terms_of_service=None), 17560a782aaba63a1114c75cbb1202fc, Meta(creation_dt=datetime.datetime(2020, 8, 4, 9, 26, 20, tzinfo=), creation_host='its-1-vm-1'))>
Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
https://acme-staging-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 724
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:07:29 GMT
Content-Length: 724
X-Frame-Options: DENY
Strict-Transport-Security: max-age=604800{
"kG5fCkqnvpc": "Adding random entries to the directory",
"keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "Staging Environment - Let's Encrypt"
"newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
"newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
"newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
"revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert"
Generating key (2048 bits): /etc/letsencrypt/keys/0023_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0023_csr-certbot.pem
Requesting fresh nonce
Sending HEAD request to https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce.
https://acme-staging-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
Received response:
HTTP 200
Server: nginx
Link: https://acme-staging-v02.api.letsencrypt.org/directory;rel="index"
Replay-Nonce: 0001dvLjP-mpT2bqlVUBiYtTJzdBblIc6eGS7NpnNiLzNUk
Strict-Transport-Security: max-age=604800Storing nonce: 0001dvLjP-mpT2bqlVUBiYtTJzdBblIc6eGS7NpnNiLzNUk
JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "smart.nysa.eu"\n }\n ]\n}'
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAxZHZMalAtbXBUMmJxbFZVQmlZdFRKemRCYmxJYzZlR1M3TnBuTmlMek5VayIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
"signature": "AgjptmNYPAz3xhzYw5nCob6WSHLhMYPh6Kbed6gWMFZdA41-K0LbNWlm7hxpVNaQfor6TIXCZ99qyzCgSxz9O-8U1dgkiiFBv-1x_uWFpOt7pWXxv4N_ODx8L50-_Y4od6V7qKqVByRxggrTKRCCIxudJg-3mn4MZJr63VGihnf4Nu4Os7865W650Sxcd00DAvvGE4Ak-ySFdiEM1n6-1kKwGCLb2PRp6I7dbCqGZITcNWGH3HGhWG4h9U2spc0EnmmAaUXzHrcYBVC1WfXAC0tWl-AjrUPXZLxx5DagxuOcpbI_eeXsuU9BLF1b-iWdGCg0z-lYG6nAT0UVsjQ15w",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogInNtYXJ0Lm55c2EuZXUiCiAgICB9CiAgXQp9"
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 356
Received response:
HTTP 201
Server: nginx
Date: Tue, 04 Aug 2020 16:07:30 GMT
Content-Length: 356
Boulder-Requester: 15002956
Location: https://acme-staging-v02.api.letsencrypt.org/acme/order/15002956/126422824
Replay-Nonce: 0001CGzA2snrhxXYvOcGfBC74Otk2q_zgq5luJIlDaFbvJI
"status": "pending",
"expires": "2020-08-11T16:07:30.096769407Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/88782123"
"finalize": "https://acme-staging-v02.api.letsencrypt.org/acme/finalize/15002956/126422824"
Storing nonce: 0001CGzA2snrhxXYvOcGfBC74Otk2q_zgq5luJIlDaFbvJI
JWS payload:
b''
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/88782123:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAxQ0d6QTJzbnJoeFhZdk9jR2ZCQzc0T3RrMnFfemdxNWx1SklsRGFGYnZKSSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84ODc4MjEyMyJ9",
"signature": "m04NgzZX_xLCB-aPdZmvHCHte2VZlMi3AjltJRKjf6YQo4NCcK_4S1bGTJbMlOaV5VbIV6OSxjHeVUmSVV2LwIs3CajBoteWEoUTb8e2RFwJgtpGU_pYpVrYH0uJX9gPTCVlt4hfhoRHwWGMtE11OkrVCfb9CvkkmhBmIZzjs4L2VGzXm07v57CNOqqbn0e2ARuzBpoLjgaC10b55ZEJQXbo5u6h7MkNkOGb_f8p_9v5y4o7UzL9Qz5yLbll4PlKAVnn6xsmZ_4Q0rOQzYt4E_ulYpsrtnW1Y682wumYkoHfgsgvPpJpBXWxCh3se5aNn2NHLLT6th7niTk8jTAtUQ",
"payload": ""
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/88782123 HTTP/1.1" 200 809
Received response:
HTTP 200
Server: nginx
Content-Length: 809
Replay-Nonce: 0002kMZ7iaqO-TqE6-Y6zDT_11dc9rZ3H6ixM2lIG_vnP6Y
"identifier": {
"type": "dns",
"expires": "2020-08-11T16:07:30Z",
"challenges": [
"type": "http-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/88782123/Jx9btA",
"token": "36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0"
"type": "dns-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/88782123/PRUEIg",
"type": "tls-alpn-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/88782123/AY1Nvw",
Storing nonce: 0002kMZ7iaqO-TqE6-Y6zDT_11dc9rZ3H6ixM2lIG_vnP6Y
http-01 challenge for smart.nysa.eu
Using the webroot path /var/www/html for all unmatched domains.
Creating root challenges validation dir at /var/www/html/.well-known/acme-challenge
Attempting to save validation to /var/www/html/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
JWS payload:
b'{\n "resource": "challenge",\n "type": "http-01"\n}'
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/88782123/Jx9btA:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAya01aN2lhcU8tVHFFNi1ZNnpEVF8xMWRjOXJaM0g2aXhNMmxJR192blA2WSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My84ODc4MjEyMy9KeDlidEEifQ",
"signature": "NqtktDZWQtXvOTE6wwpiZLjbIoEJn6oBiGzSGfIp7ajG-xJeyXciOmLnV8WsSh87dStbAg8QHUUfyOyTT9MRipHOq2iGfTN153aCUVW9mFb2EJ9uzNUsRYMh8E-7O81Vt0JuJ5iBq08Pf3dxJRIOfrSxKAXBCUDBvcE1KlvdrJxxMyX_D-gz4azX3uDEFUH6YrwU4zaFeKY8NnlcC3ex5Fcsm-86xXnOjR1ahlYZfA2cIDfW55g8ycs-oWNfcJLyW0qxMxG0W29yPE7nMmKrSPaFEAfIIRxNhAlCPLrfKjWf4o_lD5RVgWI48UNtJk4GGfYQzG0Gmlif93saPu0q4A",
"payload": "ewogICJyZXNvdXJjZSI6ICJjaGFsbGVuZ2UiLAogICJ0eXBlIjogImh0dHAtMDEiCn0"
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/88782123/Jx9btA HTTP/1.1" 200 191
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:08:07 GMT
Content-Length: 191
Link: https://acme-staging-v02.api.letsencrypt.org/directory;rel="index", https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/88782123;rel="up"
Location: https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/88782123/Jx9btA
Replay-Nonce: 0001ndLva8taE1P1ALIf5OjUOIbZgJO4xRkTkZVcVXx2vn0
"type": "http-01",
Storing nonce: 0001ndLva8taE1P1ALIf5OjUOIbZgJO4xRkTkZVcVXx2vn0
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAxbmRMdmE4dGFFMVAxQUxJZjVPalVPSWJaZ0pPNHhSa1RrWlZjVlh4MnZuMCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84ODc4MjEyMyJ9",
"signature": "EhNRCyN_bQSjOMWoNm6PmYwbrssAQ74fQPYTQm1lCXBz333NBKOyIiYAKGP9nxgbC8qvnJCBsVjktSYM5euBqz1Cyb15iJ_6vh3UNL8M5g8Juk5Q3PgIcgv9sRXHI8ZykNclRLZy-GkpVgrcqKn44463LhQEIGm58L2ZhBtjobl2W1O4JqyCpGbUF2mL0_tL68lVtfiwLir5vz9T-nSRI-vvlaogGDVotJKD7lkxYLNh5O-2ktdSji5Q5Eo6U8XqcoSW5_iZ3zNPUUs6KdMMwS_maSIsR6OCp12t1A6NgzKfjCgaHh4UbJlaOtu24JFJp4xe6VemLTE-ElFTPZZp1g",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:08:11 GMT
Content-Length: 809
Replay-Nonce: 0002bxIOh_vjDdvl10pswpvQ_UgHgnD42Bq-ZIqzzLCbkNU
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0002bxIOh_vjDdvl10pswpvQ_UgHgnD42Bq-ZIqzzLCbkNU
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAyYnhJT2hfdmpEZHZsMTBwc3dwdlFfVWdIZ25ENDJCcS1aSXF6ekxDYmtOVSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84ODc4MjEyMyJ9",
"signature": "Wjgp4WwyY_uIEqomyi2byGX1gOEDne9GOIdOml-VwtcZNPWEmbcHX46DJuk82gqkKsnR9TQafNwDiAIOoyNOC4eRK61bem4gb2lJmtzGrCBfye5yYEhvidBCXl4iUILIm2YQYyvhY-3HytCMruTo4TsWgdv_r1sui8W5ExSEhOqMAuJJRvP1EuFHrggYDITtllD8lPy1Z7JoRg8NpXLnj99fjo_At2apjpTlX1IEAFOE95Ak0tWn_FgmPV4L4JbIaCjCzT-6jqWyPDOwX0Q2-C_3h5EHrP3RzCJ2t6oR5lUq-UD95k78ybKYkiJllirppVLVpo8uag50l-oFW9jBjA",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:08:14 GMT
Content-Length: 809
Replay-Nonce: 0002OjXAbHyfI_SscXyrZSez3o-UQWLrNhylhfRH3-_yzbs
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0002OjXAbHyfI_SscXyrZSez3o-UQWLrNhylhfRH3-_yzbs
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAyT2pYQWJIeWZJX1NzY1h5clpTZXozby1VUVdMck5oeWxoZlJIMy1feXpicyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84ODc4MjEyMyJ9",
"signature": "oatLvPyMWvbuxHrcB2mrqfVW4Lfkvog_xS6QrL70Yurt9djTP4XrSOTjB_ErIUU2s-CFK_jMU0cX4kYmc5ZPniUXrlO6t_cOqhubgaH4Hi6MlctvpBtxe6_FY4RyG4dXUhgVKdR4TslK7GFic103d-btSxarNfY1Tu5jagIewI3XC99ASOGEuee1U8pNDv1ClDEokfZlYiarYs_08Dpz7UJJfYhOiXULCGWWhYt8-rYUurwJEEAtfGHqhNsQfarCFXrzexL302fQzjsqpPWZnb9ecO1g9s2ZRGESG1lAdFCsgF0BfgYIUEKryBOD9VUzabxC85nfe6fTDiSSuQp6DQ",
"payload": ""
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:08:17 GMT
Content-Length: 809
Replay-Nonce: 0002e1Bn_2d6gUql3VMnEB7tdgDxN9nsDw4KvCIKcbDtljM
"identifier": {
"type": "dns",
"challenges": [
"type": "http-01",
"type": "dns-01",
Storing nonce: 0002e1Bn_2d6gUql3VMnEB7tdgDxN9nsDw4KvCIKcbDtljM
JWS payload:
b''
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC8xNTAwMjk1NiIsICJub25jZSI6ICIwMDAyZTFCbl8yZDZnVXFsM1ZNbkVCN3RkZ0R4Tjluc0R3NEt2Q0lLY2JEdGxqTSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My84ODc4MjEyMyJ9",
"signature": "k8K7gGt3Fw8i8SOgECB3SndiqhiMKuJEI_lutl24RNvKT1hqWugm23kXNfFGZHkRomNkd3pT6QQZ9PXIgMflB72GXJ1KxD-trvfKxFO-nq0JkXLHgDxqTPZjjfNk7VuoMzJJ93CGvW-ca-ehunWKrvB8mlf4H3MK4DC3rMo61vp4L_fnjp3JMVvvk-TY-e_Cx69pHZWU3HAXhgUOZFIBL6_dEi4NxtW08HQ8bEp84-CEd4syz1mwJ4vxMZjmAAB0HDyuSwb4x-VOhdrNuXN0OhA6rP-4Gc7w9vUu3a86i-8bnZNITVvRGvRxeIS-aM1crbrmo-cPP9tvWwA6EiNXxQ",
"payload": ""
https://acme-staging-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/88782123 HTTP/1.1" 200 992
Received response:
HTTP 200
Server: nginx
Date: Tue, 04 Aug 2020 16:08:20 GMT
Content-Length: 992
Replay-Nonce: 0002KBf-8OyoIhb2Ezeh6kwRxgOcYg2Q6P981_f57mwSeso
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "Fetching http://smart.nysa.eu/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0: Timeout during connect (likely firewall problem)",
"status": 400
"token": "36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0",
"validationRecord": [
"url": "http://smart.nysa.eu/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0",
"hostname": "smart.nysa.eu",
"port": "80",
"addressesResolved": [
"78.11.72.81"
"addressUsed": "78.11.72.81"
Storing nonce: 0002KBf-8OyoIhb2Ezeh6kwRxgOcYg2Q6P981_f57mwSeso
Reporting to user: The following errors were reported by the server:Domain: smart.nysa.eu
Type: connection
Detail: Fetching http://smart.nysa.eu/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0: Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you're using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 168, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 239, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. smart.nysa.eu (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://smart.nysa.eu/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0: Timeout during connect (likely firewall problem)Calling registered functions
Removing /var/www/html/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0
All challenges cleaned up
Exiting abnormally:
File "/usr/bin/certbot", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1250, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/usr/lib/python3/dist-packages/certbot/main.py", line 121, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/client.py", line 410, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 353, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/client.py", line 389, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
Failed authorization procedure. smart.nysa.eu (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://smart.nysa.eu/.well-known/acme-challenge/36ZsxCUdNGRa-rqBbm-Ev3StriVxvq66wHuOG7OApK0: Timeout during connect (likely firewall problem)IMPORTANT NOTES:
Type: connection
Detail: Fetching
