Not able to renew
My domain is: indianeagles.team
I ran this command: Manual Verification
Certificate signature failed. If you supplied your own CSR make sure the domains on it match what you put on SSLForFree. If there is a rate limiting error at the end of this paragraph certificates per Domain is currently 5 per 7 days. Try asking Lets Encrypt to increase the limit or wait 7 days. Rate limits should increase in the near future. { “type”: “urn:ietf:params:acme:error:rateLimited”, “detail”: “Error finalizing order :: too many certificates already issued for exact set of domains: indianeagles.team,www.indianeagles.team: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }
My web server is (include version): Apache 2.4 with CWP
The operating system my web server runs on is (include version): Apache
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): CWP
Why not use one of the 10 other certificates you issued this week?
Rate Limit Current Status Domain
50 Certificates per Registered Domain per week OK (10 / 50 this week.) indianeagles.team
5 Duplicate Certificates per week Limit exceeded. Next issuable at 2018-12-22T12:28:17.000Z indianeagles.team, www.indianeagles.team
5 Duplicate Certificates per week Limit exceeded. Next issuable at 2018-12-22T12:28:12.000Z indianeagles.team
Summary generated at https://tools.letsdebug.net/cert-search?m=domain&q=www.indianeagles.team&d=168 .
I never received the certificates on the page. It always gave an error. So I tried many times. Failed! So I took help of this. I have the certificate now, where is the private key!
Do you remember what the original error was? The certificates were created just fine.
Unfortunately if you have lost your private keys and you cannot retrieve them using sslforfree.com, then they are gone forever.
At this time, you have two choices:
  1. Wait 5 days for the rate limit to elapse, or
  2. Add a third name to the certificate, so it is not considered a “duplicate”. For example x.indianeagles.team. In this case, I would suggest using a site like ZeroSSL to create the certificate instead, which may not suffer from whatever problem you ran into.
I tried ZeroSSL, which ran into the same error message. I will wait for 5 days from today. Then try ZeroSSL and also set up a cron job later, to avoid such mistakes. Thanks.
If I wasn’t clear, if you want to issue a new certificate now (and not get that error), you’d need to do it for a different set of domains.
If you’re happy to use DNS validation, you can tell ZeroSSL to give you a certificate for:
indianeagles.team *.indianeagles.team
