My hosting provider, if applicable, is: I’m hosting with https://tmdhosting.com but my homepage is hosted by SquareSpace. GoDaddy domain redirects allandbyallo.com to squarespace, but everything else is on TMD (email, webmail, cpanel etc). This is where the problems lies.
I can login to a root shell on my machine (yes or no, or I don’t know): no idea.
yes, cPanel.
Hey guys. I don’t know much about this stuff but I wanted to install LetsEncrypt as a solution, but wasn’t able to. Attaching screen shot. Each cust. support agent directs me to the other company, nobody wants to actually tell me how to resolve this. Help is greatly appreciated I’m not really all that savvy with this stuff.
Unfortunately you have found yourself in a scenario that doesn’t work so well.
The crux of the issue is that in order to issue that certificate in cPanel, the primary domain must be included on the certificate.
In your case, the primary domain is delegated to Squarespace.
As a result, you aren’t able to issue the certificate from cPanel.
The one suggestion I can make to you is that if you can delegate your domain’s nameservers to TMDHosting (rather than GoDaddy as you have it currently), you would be able to use DNS-01 validation from cPanel to issue your certificate, including for the primary domain which is delegated to Squarespace.
If you do choose to do that, you can still point your primary domain to Squarespace … just the nameservers will be different.
Here’s a rundown of the changes I think you’d need to make:
Login to GoDaddy and change your nameservers from ns31.domaincontrol.com, ns32.domaincontrol.com to:
ns1.tmd.cloud
ns2.tmd.cloud
What this achieves is that it moves control of your DNS from GoDaddy to TMD, which enables the cPanel Let’s Encrypt facility to issue certificates even if you point your website at Squarespace.
Login to cPanel and add/change the A records for www.allandbyallo.com and allandbyallo.com (in Zone Editor) to the Squarespace IP addresses (which you can find here).
What this achieves is pointing your website back to Squarespace, since in step 1, we temporarily pointed it back to TMD’s cPanel hosting.
In cPanel, try to issue the SSL certificate as you did before, but make sure to select “dns-01” (rather than the default “http-01”) on the user interface before you press “Issue”.
What this achieves is issuing the certificate using a different mechanism (DNS), which avoids running into the problem of you having your web hosting split up between TMD and Squarespace.
Visible Content: Invalid URI /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
So: What client do you use on that subdomain?
