My domain is:animatronic.in
I ran this command: sudo certbot --apache --email akorganizationdeveloper@gmail.com -d animatronic.in --agree-tos --redirect --noninteractive
Domain: animatronic.in
Type: None
Detail: No valid IP addresses found for animatronic.in
My hosting provider, if applicable, is:godaddy
or certbot-auto --version
if you’re using Certbot):
