NGINX on Ubuntu with CERTBOT, HTTPS not working
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
apiapp.admision.usach.cl
sudo certbot --nginx
1: apiapp.admision.usach.cl
2: www.apiapp.admision.usach.cl
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/apiapp.admision.usach.cl.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/nginx/conf.d/apiapp.admision.conf
nginx: [warn] conflicting server name "apiapp.admision.usach.cl" on 0.0.0.0:80, ignored
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/tomcat.conf
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains:
https://apiapp.admision.usach.cl
    /etc/letsencrypt/live/apiapp.admision.usach.cl/fullchain.pem
    /etc/letsencrypt/live/apiapp.admision.usach.cl/privkey.pem
    Your cert will expire on 2021-01-06. To obtain a new or tweaked
    with the "certonly" option. To non-interactively renew all of
    Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Ubuntu 16.04.5 x64
Linux, not sure about version
Private Server
Yes
No
certbot 0.31.0
I managed to get the certificates... http is working fine, but https gets constantly a timeout. Im new to deploy with certbot so any help will be welcome! Thanks in advance!
PS: here is my nginx -T.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	gzip_disable "msie6";
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/apiapp.admision.conf:
server_name apiapp.admision.usach.cl;
proxy_pass http://58.170.64.209/;
proxy_buffering off;
    ssl_certificate /etc/letsencrypt/live/apiapp.admision.usach.cl/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/apiapp.admision.usach.cl/privkey.pem; # managed by Certbot
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
# configuration file /etc/nginx/sites-enabled/default:
# http://wiki.nginx.org/Pitfalls
# http://wiki.nginx.org/QuickStart
# http://wiki.nginx.org/Configuration
# Generally, you will want to move this file somewhere, and start with a clean
# file but keep this around for reference. Or just disable in sites-enabled.
	listen 80 default_server;
	# SSL configuration
	root /var/www/html;
	server_name _;
		try_files $uri $uri/ =404;
	# pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
	#location ~ \.php$ {
	#	include snippets/fastcgi-php.conf;
	#	# With php7.0-cgi alone:
	#	fastcgi_pass 127.0.0.1:9000;
	#	# With php7.0-fpm:
	#	fastcgi_pass unix:/run/php/php7.0-fpm.sock;
	# concurs with nginx's one
	#location ~ /\.ht {
	#	deny all;
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
#		try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/tomcat.conf:
    if ($host = apiapp.admision.usach.cl) {
    } # managed by Certbot
  listen 80;
  access_log /var/log/nginx/tomcat-access.log;
  error_log /var/log/nginx/tomcat-error.log;
        proxy_set_header X-Forwarded-Host $host;
        proxy_set_header X-Forwarded-Server $host;
        proxy_pass http://127.0.0.1:8080/;
Thabks again!
I edited your post for clarity.
Your certificate seems to work just fine - it's just that your server isn't producing an HTTP response afterwards.
What seems most probable is that your server is waiting for a response from http://58.170.64.209, but that server doesn't seem to be responding on port 80
I would double-check that the remote server is setup correctly, and investigate whether it's suitable for you to setup a proxy_connect_timeout so your server doesn't sit there hanging pointlessly.
I would suggest you to take a backup of your Nginx folder /etc/nginx before you do anything described in the following paragraph.
I assume you are trying to use your tomcat server, which is deployed locally to serve requests, so I did some work and help you merged both configuration.
  listen 80;
  listen [::]:80;
  listen [::]:443 ssl http2;
  listen 443 ssl http2;
  # tell users to go to SSL version this time
  if ($ssl_protocol = "") {
    rewrite ^ https://$host$request_uri? permanent;
The above file should replace your configuration file at
/etc/nginx/sites-enabled/tomcat.conf, if you have this you should remove /etc/nginx/conf.d/apiapp.admision.conf.
P.S. If @_az had time, can you help me format the above codeblock? My Firefox on Android sucks (after their "new" version) and can't properly format / select and even show this input box correctly... Somehow it'll always be buried under my keyboard layout)
Thanks in advance!
@stevenzhu
You did some good work there :+1:
The only feedback I have to offer is:
  • Single server blocks with multiple listens tend to get mangled more easily by certbot
  • Using multiple server blocks can offer certain optimalities like shorter/clearer code and avoiding unnecessary conditional checks (e.g. no need to check for ssl protocol when only listening to ssl)
