Certbot --nginx not working
teemo-world.link
sudo certbot --nginx
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: teemo-world.link
Requesting a certificate for teemo-world.link
  Domain: teemo-world.link
  Type:   connection
  Detail: 121.131.231.182: Fetching http://teemo-world.link/.well-known/acme-challenge/rDwcINxPnfyk5xy9-M0rRqie6_XWnCvh4XJrk1bQRa4: Timeout during connect (likely firewall problem)
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu22.04
route 53
curl http://teemo-world.link
response 200
Not from my part of the world. And apparently also not from Let's Encrypts.
Make sure port 80 (and 443) are open from the entire global internet.
Adding to what @Osiris has already mentioned about Ports 80 and 443, I see this.
$ nmap -Pn -p80,443 teemo-world.link
Starting Nmap 7.80 ( https://nmap.org ) at 2023-08-27 20:06 UTC
Nmap scan report for teemo-world.link (121.131.231.182)
Host is up.
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.88 seconds
