My domain is: sim-hub.poly.edu
I ran this command: sudo certbot --nginx
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): sim-hub.poly.edu
Requesting a certificate for sim-hub.poly.edu
Domain: sim-hub.poly.edu
Type: connection
Detail: 128.238.147.29: Fetching http://sim-hub.poly.edu/.well-known/acme-challenge/YGQy4rk3iK4fu1pgdwwrV0OnPL_aW014sTvJxMd4dF8: Timeout during connect (likely firewall problem)
My web server is (include version): nginx version: nginx/1.20.1
NAME="Red Hat Enterprise Linux"
VERSION="9.3 (Plow)"
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
