Nginx https is not working
My domain is: legale.io
I ran this command: certbot --nginx -d legale.io -d www.legale.io
It produced this output: Success
My web server is (include version): nginx/1.14.0
The operating system my web server runs on is (include version): Ubuntu
My hosting provider, if applicable, is: Azure
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.27.0
Hi @babytiger, and welcome to the LE community forum :slight_smile:
Please show the following outputs:
certbot certificates
nginx -T
[and both (nginx and certbot) could benefit from an update]
Thank you for your reply. Here you go the print of your commands.
  • certbot certificates
    Found the following certs:
    Certificate Name: legale.io
    Domains: legale.io www.legale.io
    Expiry Date: 2021-09-27 23:02:46+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/legale.io/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/legale.io/privkey.pem
  • nginx -t
Welcome to the Let's Encrypt Community, Zhang :slightly_smiling_face:
@rg305 was wanting the output of:
sudo nginx -T
The sudo and capital "T" are very important here.
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 65;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
	listen 80 default_server;
	# SSL configuration
	root /var/www/html;
	server_name _;
		try_files $uri $uri/ =404;
	#location ~ \.php$ {
	#	include snippets/fastcgi-php.conf;
	#	# With php-fpm (or other unix sockets):
	#	fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
	#	# With php-cgi (or other tcp sockets):
	#	fastcgi_pass 127.0.0.1:9000;
	# concurs with nginx's one
	#location ~ /\.ht {
	#	deny all;
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
#		try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/legale.io:
        server_name legale.io www.legale.io;
                proxy_pass http://127.0.0.1:8000$request_uri;
                proxy_redirect off;
                proxy_set_header HOST $host;
                proxy_set_header X-Fowarded-Host $server_name;
                proxy_set_header X-Fowarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-NginX-Proxy true;
                proxy_connect_timeout 5000s;
                proxy_read_timeout 5000s;
                proxy_http_version 1.1;
                proxy_set_header Connection "upgrade";
    listen [::]:443 ssl;
    ssl_certificate /etc/letsencrypt/live/legale.io/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/legale.io/privkey.pem; # managed by Certbot
    if ($host = www.legale.io) {
    } # managed by Certbot
    if ($host = legale.io) {
    listen 80;
    listen [::]:80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
sorry to this long text :slight_smile:
I only see a possible problem when you will need to renew your cert.
The current topic problem appears to be related to port 443 being blocked or nor forwarded correctly.
HTTP connections work and receive the redirection instructions.
HTTPS connections time out.
curl -Iki http://legale.io/
Server: nginx/1.14.0 (Ubuntu)
Date: Wed, 30 Jun 2021 14:43:39 GMT
Content-Type: text/html
Content-Length: 194
curl -Iki https://legale.io/
curl: (7) Failed to connect to legale.io port 443: Connection timed out
As for the future, potential, renewal problem: You may need to include a specialized handling location block for the challenge requests.
Hello @rg305
So the certbot is no problem so far?
Thank you very much, I will try to check all things again.
I will leave here if I find a good solution.
To ensure, please show:
This one?
Yes, that is the needed cert.
So, certbot is not the problem.
Just to be sure, please restart, or reload, nginx.
Like:
systemctl restart nginx
OR show the output of:
sudo netstat -pant | grep -Ei 'nginx|:443'
I was trying to restart nginx so many times but no effect.
Here you go the result of your last command.
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 14926/nginx: master
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 14926/nginx: master
tcp 0 0 10.0.1.22:35142 40.79.154.87:443 TIME_WAIT -
tcp 0 0 10.0.1.22:35176 40.79.154.87:443 TIME_WAIT -
tcp 0 0 10.0.1.22:35174 40.79.154.87:443 TIME_WAIT -
tcp 0 0 10.0.1.22:35220 40.79.154.87:443 TIME_WAIT -
tcp6 0 0 :::80 :::* LISTEN 14926/nginx: master
tcp6 0 0 :::443 :::* LISTEN 14926/nginx: master
@rg305
Since @babytiger is using the --nginx authenticator, certbot should temporarily create this itself during the authentication process, which will avoid the http to https redirect.
If this test succeeds:
sudo certbot renew --dry-run
we know for sure.
@babytiger
Please run the following command and let us know the output:
kill -KILL $( cat /usr/local/nginx/logs/nginx.pid )
Finally, I found why.
You guys were right, there was no problem in certbot, it was the problem in VM.
Actually, I am using Ubuntu VM of Azure, and I forgot to open port 443 on Azure VM networking configuration.
I hope nobody face this silly problem later.
Thank you guys.
You are very welcome. :blush:
Glad it worked out.
Don't be hard on yourself here. We see basically the same issue many times per week. Often it's port 80 that's blocked though.
