sudo certbot --nginx -d img.api.directoryfox.com
Attempting to parse the version 0.34.2 renewal configuration file found at /etc/letsencrypt/renewal/dev1.directoryfox.com.conf with version 0.31.0 of Certbot. This might not work.
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/img.api.directoryfox.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/img.api.directoryfox.com
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Traffic on port 80 already redirecting to ssl in /etc/nginx/sites-enabled/img.api.directoryfox.com
Congratulations! You have successfully enabled https://img.api.directoryfox.com
https://www.ssllabs.com/ssltest/analyze.html?d=img.api.directoryfox.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/img.api.directoryfox.com/fullchain.pem
/etc/letsencrypt/live/img.api.directoryfox.com/privkey.pem
Your cert will expire on 2020-03-12. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Ubuntu 16.04.5 x64
Linux, not sure about version
Digital Ocean
Don’t know, but I have sudo access on my user
no
certbot 0.31.0
After all of this I have tried to no avail to get HTTPS to work. I am happy to paste my sites-enabled file and all of that for help. Thank you!
