Newbie Needs More Help
My domain is: caribsis.com
I ran this command: certbot certonly --agree-tos --email datsys.computerservices@gmail.com --webroot -w /var/lib/letsencrypt/ -d caribsis.com -d www.caribsis.com
It produced this output: IMPORTANT NOTES:
    Domain: www.caribsis.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up A for www.caribsis.com -
    check that a DNS record exists for this domain
  • Your account credentials have been saved in your Certbot
My web server is (include version): Apache2
My hosting provider, if applicable, is: Digital Ocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Kitty
How do I fix that error?
To use HTTP validation, you need to add one or more relevant DNS records at your DNS provider (Dynadot, apparently).
caribsis.com has this A record, giving its IPv4 address:
caribsis.com.  10800  A   161.35.106.52
www.caribsis.com has no DNS records at all.
I don't use Dynadot, but it looks like they have documentation that shows how to add both records (including the one you already added, so you should be able to skip that step):
To quote it:
  1. In the "Subdomain Records (optional)" section, enter "www" as the subdomain, select "A" from the drop-down menu and then enter your IP address in the "IP Address or Target Host" box.
Thank you for responding. Now that the procedure goes through, I am able to get as far as the sign in page of the site but after signing in it goes to a page can’t be reached error. The suggested solution is to start the server installation from scratch but after installing Apache I should go through teh Lets Encrypt procedure to make the server HTTPS so that I would use https://mydomainname.com to bring up the Apache Default page that confirms the web server is running.
Can this be done?
