My domain is: prism.finplex.in
Someone installed SSL certficate to the domain three months back, but now its Expired. I would like to know If I have access key and other files, How can I renew a SSL certifcate.
Let's Encrypt doesn't have access to the private key which was used to generate the CSR. You're the only one with access to it.
Hi @saratherv45,
There are dozens of different software applications that are used to request and renew Let’s Encrypt certificates, so there’s no one single way to do this. It depends on what software is used to host your site. Can you describe your hosting environment and how you administer the site?
