Can u pls help how to renew let's encrypt certificate?
can u pls help how to renew let's encrypt certificate?
usually my hosting do it , but now my client ask this ssl certificate to be install to their server. my host already give me the files of the certicate ( there's button to install it but i don't see how to renew it )
i want to renew it from my side before i sent to my client ... can u pls help ?
thanks
Hello @clarencecloud you are welcome here!
We would love to help you. But could you please give us some more information?
If this isn't your preferred language could you let us know so we can better communicate?
hi Rip
thanks so much for your reply
is it okay to share the domain name here ? since it's so public?
thanks
Dear Rip,
sorry i'm not IT guy ....so i tried this :
crt.sh ID
4458022215
4458004982
C=US, O=Let's Encrypt, CN=R3
Can u pls help to extend ( renew) to 3 months later ?
Thanks so much ...
Hi @clarencecloud,
Let's Encrypt certificates aren't approved by human beings; nobody here has the power to approve a renewal or make it happen. It depends on the configuration of your web server.
That's why @Rip asked you for more details about how and where your site is hosted. The details of how to renew Let's Encrypt certificate depend on the hosting environment, and are potentially different for every hosting environment and technology.
Dear Schoen,
thanks so much for your help.
So the best thing, is I need to ask my host to renew it , is it correct?
Thanks so much
Even that depends on the nature of the hosting environment.
If you have a VPS hosting plan, where you are the system administrator, there may be a command for you to run to request the certificate renewal.
If you have a shared hosting plan, where you aren't the system administrator, there may be a button to renew your certificate in your control panel.
If you have a plan where the web host itself obtained or installed the certificate for you, then the web host will also need to repeat that process in order to renew the certificate.
thanks so much Schoen
i'll ask my host first
