Need help with DNS process for encryption https:
My domain is: Should be https:www.virgin-deas.myshopify.com
My hosting provider, if applicable, is: Shopify
I can login to a root shell on my machine (yes or no, or I don’t know): Need assistance with DNS process can someone help with the process. I was getting error message in he Google verification panel
Hi @KatinaLarkin
I don't think that's possible. Checking your domain - https://check-your-website.server-daten.de/?q=virgin-deas.myshopify.com#connections
there is a shop with a wildcard:
CN=*.myshopify.com, O="Cloudflare, Inc.", L=San Francisco, S=CA, C=US
	20.04.2020
	09.10.2020
expires in 50 days	myshopify.com, *.myshopify.com - 2 entries
That works with the non-www, but not with the www version of your domain.
And I don't think you are able to install a certificate and to replace the wildcardcard.
So you should remove your www dns entry.
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
virgin-deas.myshopify.com CNAME shops.myshopify.com yes 1 0
A 23.227.38.64 Montreal/Quebec/Canada (CA) - Cloudflare, Inc. Hostname: shops.myshopify.com yes
www.virgin-deas.myshopify.com CNAME shops.myshopify.com yes 1 0
*.myshopify.com A 23.227.38.64 yes
AAAA yes
*.virgin-deas.myshopify.com A 23.227.38.64 yes
AAAA yes
But there is a DNS wildcard *.myshopify.com, so that system is a little bit curious.
And you can't change that, because it's a myshopify.com dns entry.
So the wildcard creates a working dns www entry, but the system doesn't support the www + https.
You’ve already opened a thread about the same website. Please continue there.
When I log into my domain on google without the www but only with the name of virgin-deas.myshopify.com domain it automatically logs into my store and FB account. Is this normal
Okay so saying I am fine, good. Thank you so much for your help!
It could be Google needs some more time perhaps. I’m not sure, because it’s been a while for me using the Google Search Console.
At least from a technical point of view there’s nothing wrong with your HTTPS.
