I need help on my SSL certificate
My domain is: ambitious-mind.com
My hosting provider, if applicable, is: netlify
I can login to a root shell on my machine (yes or no, or I don’t know):no
Hi @Bryans
your website uses a wildcard certificate ( https://check-your-website.server-daten.de/?q=ambitious-mind.com ):
	CN=*.ambitious-mind.com
	05.05.2019
	03.08.2019
expires in 28 days
*.ambitious-mind.com, ambitious-mind.com - 2 entries
So you have to use dns-01 validation.
How did you create that certificate? With the --manual option? If yes, do that again.
Hello, I really don’t know how to do this. Please can u assist me?
What do you need help with?
The problem has been resolved thanks.
