Hello fellow Sys Admins. Rookie here seeking for help.
I have setup a web server running on NGINX on Debian 9 Stretch and managing my domain on Cloudflare.
I managed to install an SSL cert for my root domain using certbot with the dns-cloudflare argument to install an SSL. This is one works flawlessly when accessing the root domain, say example.com its www subdomain. The root domain serves a WordPress installation.
I want to serve a Prestashop installation on a sub-domain - shop .example.com
I’ve already installed Prestashop and can access it through the shop sub-domain but can’t get a SSL working on that particular sub-domain. Any ideas on how to go about this?
netprosystems.co.ke. 300 A 104.28.28.76
netprosystems.co.ke. 300 A 104.28.29.76
shop.netprosystems.co.ke. 300 A 41.80.91.20
www.netprosystems.co.ke. 300 A 104.28.28.76
www.netprosystems.co.ke. 300 A 104.28.29.76
Can you post the Nginx configuration? "sudo nginx -T" will display it.
The redirect is not a normal redirect generated by Nginx. It's possible that PrestaShop itself is producing it. If so, that might be fixed by setting PrestaShop's "Enable SSL" setting or something.
Sorry I forgot to close the quotation mark but I ran the command, SSL was successfully installed, but only works for www.netprosystems.co.ke but not shop.netprosystems.co.ke
shop.netprosystems.co.ke is also under Cloudflare’s CDN but I can’t access the Prestashop installation under that subdomain when I enable Cloudflare’s proxy on it that’s why I’ve disabled it for now. If I enable proxy on shop.netprosystems.co.ke, it redirects to the root domain - www.netprosystems.co.ke
Running sudo nginx -T produces the following:
user www-data;
worker_processes 2;
pid /run/nginx.pid;
events {
worker_connections 1024;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
server_tokens off;
server_names_hash_bucket_size 64;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
gzip_vary on;
gzip_proxied any;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
gzip_min_length 256;
# Virtual Host Configs
# set client body size to 2M #
client_max_body_size 60M;
client_body_buffer_size 128k;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-auth-pam.conf:
load_module modules/ngx_http_auth_pam_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-dav-ext.conf:
load_module modules/ngx_http_dav_ext_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-echo.conf:
load_module modules/ngx_http_echo_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-subs-filter.conf:
load_module modules/ngx_http_subs_filter_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-upstream-fair.conf:
load_module modules/ngx_http_upstream_fair_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/shop.netprosystems.co.ke:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# listen 80;
#listen [::]:80;
#server_name shop.netprosystems.co.ke;
#return 301 https://$host$request_uri;
#listen 80;
#listen 443;
#ssl on;
#ssl_certificate /var/www/cloudflare-ssl/shop.netprosystems.co.ke.pem;
#ssl_certificate_key /var/www/cloudflare-ssl/shop.netprosystems.co.ke.key;
# SSL configuration
# listen 443 ssl;
root /var/www/shop.netprosystems.co.ke/prestashop;
index index.php index.html index.htm index.nginx-debian.html;
server_name shop.netprosystems.co.ke www.shop.netprosystems.co.ke;
#ssl_certificate /etc/letsencrypt/live/shop.netprosystems.co.ke/fullchain.pem;
#ssl_certificate_key /etc/letsencrypt/live/shop.netprosystems.co.ke/privkey.pem;
#include /etc/letsencrypt/options-ssl-nginx.conf;
#ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
try_files $uri /index.php?$args;
#try_files $uri $uri/ =404;
# define error page
error_page 404 = @notfound;
# error page location redirect 301
location @notfound {
return 301 /;
location ~ \.php$ {
include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
#intercept errors for 404 redirect
fastcgi_intercept_errors on;
# concurs with nginx's one
location ~ /\.ht {
deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
#server {
# if ($host = www.netprosystems.co.ke) {
# return 301 https://$host$request_uri;
# } # managed by Certbot
# if ($host = netprosystems.co.ke) {
## } # managed by Certbot
# listen 80 ;
# listen [::]:80 ;
# server_name netprosystems.co.ke www.netprosystems.co.ke;
# return 301 https://www.netprosystems.co.ke; # managed by Certbot
# configuration file /etc/nginx/snippets/fastcgi-php.conf:
# regex to split $uri to $fastcgi_script_name and $fastcgi_path
fastcgi_split_path_info ^(.+\.php)(/.+)$;
# Check that the PHP script exists before passing it
try_files $fastcgi_script_name =404;
# Bypass the fact that try_files resets $fastcgi_path_info
# see: http://trac.nginx.org/nginx/ticket/321
set $path_info $fastcgi_path_info;
fastcgi_param PATH_INFO $path_info;
fastcgi_index index.php;
include fastcgi.conf;
# configuration file /etc/nginx/fastcgi.conf:
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT $document_root;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REQUEST_SCHEME $scheme;
fastcgi_param HTTPS $https if_not_empty;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx/$nginx_version;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param REDIRECT_STATUS 200;
# configuration file /etc/nginx/sites-enabled/www.netprosystems.co.ke:
listen 80;
listen [::]:80;
server_name *.netprosystems.co.ke;
# SSL configuration
listen 443 ssl;
root /var/www/netprosystems.co.ke;
server_name *.netprosystems.co.ke www.netprosystems.co.ke;
ssl_certificate /etc/letsencrypt/live/shop.netprosystems.co.ke/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/shop.netprosystems.co.ke/privkey.pem; # managed by Certbot
# define error page
return 301 /;
location ~ \.php$ {
location ~ /\.ht {
deny all;
#server {
# listen 80;
# listen [::]:80;
# index index.html;
# location / {
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
I haven’t meddled with Prestashop at all after installing, let me check if there’s a ‘Enable SSL’ option
