Sub domain can not resolve after using certbot
I ran this command: sudo certbot --nginx
It said everything was configured properly. I closed my terminal window at this point, thinking everything was good since I generated plenty of certs for wordpress sites so nginx should be no problem.
Instead I discover the subdomain is now totally inaccessible in both http and https. I even tried to revert to the old configuration settings and it still does not work. I totally regret not just doing sudo certbot certonly --nginx and manually setting it up.
My web server is (include version): nginx version: nginx/1.20.1
The operating system my web server runs on is (include version): Ubuntu 20.4
My hosting provider, if applicable, is: Lightsail
certbot 1.20.0
It looks like nginx is not running at all, is the configuration in a state where it can be started?
sudo nginx -t
It was. All of my other sub domains worked. But I decided to destroy my cloud instance and start over.
redacted
It sounds like you might need to open TCP port 443 in your Lightsail control panel or the instance firewall, or both.
HTTP: port 80
HTTPS: port 443
haha yes that was it! Silly me, I didn't realize an "OS only" instance of Lightsail would have that port closed by default! Thank you for the tip!
