Installing, DNS, subdomains..... help my spaghetti-entangled head
certbot version 1.12
Debian 10 - updated
Apache
Yes, SSH access
Apache 2.4.38-3+deb10u4 amd64
I'm trying to get SSL setup on a new server, and the plethora of options is getting foggy, since we don't exactly fit into the standard scenarios. Any guidance much appreciated!
Note: Any details below that provoke a "why on this planet would you do that" would generally be answered with "it's legacy, and I haven't gotten that far down the to-do list". :grin:
We host our own DNS. The PRIMARY domain [mountdesales.net] is hosted off-campus, and uses a wildcard cert from GoDaddy. We host several SUBdomains here on campus [for example, tech.mountdesales.net]. There are several others - basically anything OTHER than www.mountdesales.net. Some already exist on this machine, others will be moved over when the time is right.
  • Why not just use the GoDaddy cert on our local machine? It's a pain. Can't be autorenewed, so once a year I have to go muck around the server. It's also $400, and we're a school. Eventually I hope to use LetsEncrypt for the primary site, but that can't happen this week.... or next.
There's the background.
What I've done so far [assuming I remember correctly]:
  • Installed pip3.
  • Using pip3, installed certbot and certbot-dns-standalone.
  • Had to upgrade cryptography [pip3 install -U cryptography].
So:
  1. Do I try for a wildcard cert on this server, given we already have a wildcard cert for the main domain?
  2. or do I just install individual subdomain certs for each subdomain?
  3. What's the best/easiest procedure to make this happen?
  4. Any headache-avoidance strategies you can suggest?
Thanks!
Hopefully one day I can return the favor
Hi @MDStech
  1. you can. The GoDaddy wildcard isn't relevant. You can create a single wildcard and deploy it to all of your machines. With dns validation.
  2. You can too. Do you have 10 - 30 subdomains? Or more then 50? More then 50 - check the rate limit page. Non-wildcard -> http validation is possible, but if you have a working dns update, you can use dns validation.
Choose a solution and start with the first subdomain.
