Subdomain issues
My domain is: https://ururu.shop, https://cosme.ururu.shop, https://case.ururu.shop
ubuntu 16.04 + Nginx 1.9 + Php7.0-fpm + Mariadb 10
YES
NO
Hi
Im using Letsencrypt certificate in several subdomains.
There is no problem with applying the certificate to domains on server, but some browsers (like Galaxy S and UCbrowser) says appears have not been trusted domain. (Chrome, Ios is ok)
I tried to test on https://www.ssllabs.com/, result is A+
I dont understand what is the problem.
Please let me know how to fix this problem.
do you know what the browsers on those phones are
trying using the legacy ciphers recommended by mozilla.
https://wiki.mozilla.org/Security/Server_Side_TLS
a solid working solution for LE and SSL on Nginx is a host .conf file like this, this includes all the correct ciphers as @ahaw021 mentioned and all ssl settings that Nginx needs.
	# SSL configuration
	listen 443 ssl http2;
	root /var/www/mywebsite.com;
	server_name mywebsite.com www.mywebsite.com;
	charset UTF-8;
	access_log /var/log/nginx/mywebsite.com-access.log;
	error_log /var/log/nginx/mywebsite.com-error.log;
	# First include our certificates and chain of trust
	ssl_certificate /etc/letsencrypt/live/mywebsite.com/fullchain.pem;
	ssl_certificate_key /etc/letsencrypt/live/mywebsite.com/privkey.pem;
	## verify chain of trust of OCSP response using Root CA and Intermediate certs
	ssl_trusted_certificate /etc/letsencrypt/live/mywebsite.com/chain.pem;
	# Diffie-Hellman parameter for DHE ciphersuites, recommended 2048 bits
	ssl_dhparam /etc/nginx/ssl/dhparam.pem;
	ssl_session_timeout 1d;
	ssl_session_cache shared:SSL:128m;
	ssl_session_tickets off;
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
	# ciphers recommended by https://mozilla.github.io/server-side-tls/ssl-config-generator/
	ssl_ciphers 'ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS';
	ssl_prefer_server_ciphers on;
	add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
	ssl_stapling on;
	ssl_stapling_verify on;
	listen 80;
        return 301 https://mywebsite.com$request_uri;
# END OF HTTP PORT 80 HOST CONFIG - CLOSING BRACE BELOW THIS LINE
