My website is not working on https by using letsencrypt certificates
Hi
Presently i am using ubuntu server 16.04.1 operating system with apache2 web browers.
previously our site is works on ssl but now its not work
its show an error message see below
An error occurred during a connection to www.colourssoftware.com. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
hi @MahendraReddy
have you done any troubleshooting on this?
Do you have any idea what has changed?
https://www.digicert.com/ssl-support/apache-fix-common-ssl-errors.htm
May be a starting point
Andrei
i am did not do any changes on my apache web server
I followed up to another thread indicating that this is caused by speaking HTTP on port 443 instead of HTTPS. The web server configuration needs to be set to use HTTPS, not HTTP, on port 443.
As @ahaw021 said, please don’t create duplicative forum threads about the same problem. Separate threads about different problems that the same person is having are OK. :slight_smile:
