My SSL stop working after few Minutes since SSL installation
My domain is: metizapps.com
My web server is (include version): Apache2
The operating system my web server runs on is (include version): ubuntu14.04
My hosting provider, if applicable, is: AWS (Amazon)
My SSL stop working after few Minutes since SSL installation. Please let me know if you need more detail. Right now I have removed letsencrypt because its stopped my site
Hi @jaydip.kansagra
you have some Letsencrypt certificates ( https://check-your-website.server-daten.de/?q=metizapps.com#ct-logs ):
CertSpotter-Id Issuer not before not after Domain names LE-Duplicate next LE
972804569 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-18 04:14:28 2019-09-16 04:14:28 metizapps.com, www.metizapps.com - 2 entries duplicate nr. 1
950178073 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-05 04:17:26 2019-09-03 04:17:26 metizapps.com, www.metizapps.com - 2 entries
950162258 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-05 04:05:53 2019-09-03 04:05:53 metizapps.com, www.metizapps.com - 2 entries
950142181 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-05 03:53:09 2019-09-03 03:53:09 metizapps.com, www.metizapps.com - 2 entries
950126586 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-05 03:42:23 2019-09-03 03:42:23 metizapps.com, www.metizapps.com - 2 entries
951202438 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-06-05 03:04:53 2019-09-03 03:04:53 metizapps.com, www.metizapps.com - 2 entries
One is new, five are from 2019-06-05, looks like you have hitted the limit.
But you don't use it, instead there is another certificate
CN=metizapps.com
	17.12.2018
	17.01.2020
expires in 213 days	metizapps.com, *.metizapps.com - 2 entries
from Amazon. And the chain is wrong:
Chain - too much certificates, don't send root certificates
	1	CN=metizapps.com
	2	CN=Amazon, OU=Server CA 1B, O=Amazon, C=US
	3	CN=Amazon Root CA 1, O=Amazon, C=US
	4	CN=Starfield Services Root Certificate Authority - G2, O="Starfield Technologies, Inc.", L=Scottsdale, C=US, ST=Arizona
You use the certificate - Grade E. There are some older checks with Grade T, https didn't answer.
That’s a certificate issued and controlled by AWS – probably on an ELB? I don’t think there’s any way to control how Amazon configures the chain. It’s inefficient, but valid and probably very backwards compatible.
@jaydip.kansagra, when you say the certificate will “stop working”, what do you mean? Do you get an error message? If so, what is it? What’s generating it?
Are you configuring a Let’s Encrypt certificate on Apache or what?
Hello @JuergenAuer
I did try to install letsencrypt SSL but every time I got the issue (SSL stop working after few minutes )
Is there any request limit? because this domain / server have lots of requests.
Your question : when you say the certificate will “stop working”, what do you mean? Do you get an error message? If so, what is it? What’s generating it?
Answer : Stop working mean : SSL not connect after few minutes
  1. Do you get an error message?
    Ans : No, its just time out, Not shake hand with SSL
Please let me know if you have any suggestion on this.
Thanks,
Jaydip Kansgra
You can use Letsencrypt. But you don't use it. And you don't need 5 identical certificates in one week. So there is a rate limit. Create one certificate, then use it 60 - 85 days.
I don't understand that problem. That is only a local installation problem, that has nothing to do with Letsencrypt. If the certificate is created and downloaded, Letsencrypt is done.
Sounds like a special problem in your application. So changing the certificate -> the application crashes or is stopped.
Hello @JuergenAuer
Its same like : Website stop working after few hours since SSL installation
Interesting, thanks to share that old topic.
There answered another instance, you have a timeout. Timeouts are terrible - no answer.
But now, I have no idea how to debug that. If there is a timeout, is your server running?
Yes, My server is running with AWS SSL, but right now there is no letsencrypt SSL certificate in my server. Do I need to re-install letsencrypt SSL so you can get better idea about this issue.
