Tobeas
March 30, 2023, 4:35pm
1
Good day,
I may not be in the right place here but unfortunately I can't find the right solution anywhere.
On some computers and browsers, the certificate of my website is not trusted, so my website is not opened.
I've tried everything, I'm not a programmer, but I can't solve it.
My domain name is https://tobiasphilipp.nl/ and I use the hosting services of Cloud86. My control panel is Plesk.
Thank you in advance and I hope someone can help me.
Can you show an example error from one of those failing systems?
Because your cert looks fine to me
Such as which ones?
Have you cleared the browser cache on those browsers and exited the browser and restarted the browser?
Have you tried rebooting the computers?
rg305
March 30, 2023, 9:48pm
4
Bruce5051:
Such as which ones?
How old are those failing devices?
What O/S version are they using?
This sounds like the failing devices don't trust the "short LE chain".
rg305
March 30, 2023, 10:02pm
6
User may have no control of which chain is used - likely on "shared hosting".
I wish all clients did the Path Building vs Path Verifying the way indicated here Verifying a certificate - #5 by jsha
To me it seems clients (web browsers, openssl, etc.) are to some extent broken.
rg305
March 31, 2023, 10:21am
10
"Blocked categories" sounds like there is a firewall in use.
Tobeas
March 31, 2023, 10:40am
11
Thank you for your help! Could it be that setting or category has to be changed to be accepted by this firewall?
rg305
March 31, 2023, 10:47am
12
Yes, that is likely.
It should be the firewall controlling the outbound connections to the Internet for that system that is blocking.
Two suggestions for the firewall admin:
the block notice should include the system names or IPs that is doing the block and being blocked
the block notice should include a contact name or number to request an exception to this block
rg305
March 31, 2023, 11:04am
13
I don't know which firewall system is being used...
But checking with Fortinet/Fortiguard, I do see:
It might just be that the site is too new.
Tobeas
March 31, 2023, 11:08am
14
Thank you very much for your help! Is there anything I can do to change this?
rg305
March 31, 2023, 11:13am
15
Possibly...
But it depends on knowing what system was doing the blocking and mainly where it got the information.
I also have two recommendations for your host [if you get a chance to speak with them]:
enable TLS v1.3
enable IPv6
Tobeas
March 31, 2023, 11:45am
16
Thank you very much for your help, I appreciate it! I will contact my hosting provider.
system
Closed
April 30, 2023, 11:46am
17
