Create your three vHosts, then create the certificates.
Thats what I have now
And what’s the problem?
I don’t see new certificates. One from 2018-09-20 - intranet.lsgob.us
But I thought you want www + non-www, so create this certificate with
-d www.intranet.lsgob.us -d intranet.lsgob.us
And your vHost must have both names as server names.
Like this?
<VirtualHost *:80>
ServerName intranet.lsgob.us
ServerAdmin ayuda@roozgames.com
DocumentRoot /var/www/intranet
</VirtualHost>
<VirtualHost *:80>
ServerName www.intranet.lsgob.us
</VirtualHost>
Please create one vHost with two names, not two. Two vHosts -> much more complicated.
https://httpd.apache.org/docs/2.4/vhosts/examples.html
ServerAlias www.intranet.lsgob.us
Same with your other two name pairs.
<VirtualHost *:80>
</VirtualHost>
Like this? that is what I have at the beggining but didn't worked either. I will try it again
Yes. Now try to create one certificate with two domain names (use the -d - option).
Look at your older post:
If you have one vHost with two names and two certificates with one domain name, you can't use two certificates with this one vHost. So www or non-www is wrong.
But there is a redirect http -> https intranet.lsgob.us, but no www - redirect. So I hope that isn't a problem.
Now you have the other solution:
One wildcard certificate *.lsgob.us
Used with
https://intranet.lsgob.us/
https://pd.lsgob.us/
https://lsgob.us/
That’s possible. But then change the links on the page https://lsgob.us/ - remove the www.
