Problems with mismatch of domain names
I have a apache config with one site that has multiple domain names. My problem is that when the domain name looks too much the same it makes a name mismatch and the certificate don't work.
So, if I first get a certificate for:
epiichaircare.dk
Then makes another for:
epiichairshop.dk
Only that last run will work. I also tried to "Renew & replace" the first one. Now, only that one works and the other fails. It works fine when the domain name is something completely different.
You can see the failed domain at:
Any ideas?
sudo certbot --apache
Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.1
Yes
certbot 0.40.0
I was wrong. It doesn't work with different domains either. I must be using the wrong command to do this. How to I get a certificate for all three domains or can I change something in the config?
All you had to do is create multiple vhost entries in the .conf file. Works now :slight_smile:
Hi @madeby
yes, that's the basic requirement if you want to use --apache.
One port 80 vHost -> one certificate -> one template to create the port 443 vHost.
Happy to read you have found a solution :+1:
And please show us the output of the command.
