I found problem while installing certificate in Apache
I run this command: sudo certbot --apache
Requesting a certificate for platform.EXAMPLE.com
Domain: platform.EXAMPLE.com
Detail: 2a02:4780:1e:b0c5:b9b:15a5:3510:369c: Invalid response from http://platform.EXAMPLE.com/ .well-known/acme-challenge/2FU35paxLaZIrPa2aWjqDeCX3mJ8l54XvosXA_7LQwI: 404
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: hostinger VPS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.21.0
When I run "certbot certificates" it shows "No certificates found."
When I run " sudo apachectl -t -D DUMP_VHOSTS" It shows "VirtualHost configuration:
*:80 platform.EXAMPLE.com (/etc/apache2/sites-enabled/platform.conf:1)"
This is the error log
" tail -n 30 /var/log/letsencrypt/letsencrypt.log"
2023-10-23 11:03:36,993:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==1.21.0', 'console_scripts', 'certbot')())
File "/usr/lib/python3/dist-packages/certbot/main.py", line 15, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1574, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1287, in run
new_lineage = _get_and_save_cert(le_client, config, domains,
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 133, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 459, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 389, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 439, in _get_order_and_authorizations
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 90, in handle_authorizations
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 178, in _poll_authorizations
2023-10-23 11:03:36,993:ERROR:certbot._internal.log:Some challenges have failed.
2023-10-23 11:06:40,777:DEBUG:certbot._internal.main:certbot version: 1.21.0
2023-10-23 11:06:40,778:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2023-10-23 11:06:40,778:DEBUG:certbot._internal.main:Arguments:
2023-10-23 11:06:40,778:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2023-10-23 11:06:40,784:DEBUG:certbot._internal.log:Root logging level set at 30
2023-10-23 11:06:40,785:DEBUG:certbot._internal.display.obj:Notifying user: No certificates found.
And my conf file
<VirtualHost *:80>
    DocumentRoot "/var/www/project-management/public"
    DocumentRoot /var/www/project-management/public
    ServerName platform.******.com
    <Directory /var/www/project-management/public>
        AllowOverride All
        order deny,allow
        Require all granted
    </Directory>
</VirtualHost>
And my .htaccess file
<IfModule mod_rewrite.c>
    <IfModule mod_negotiation.c>
        Options -MultiViews -Indexes
    </IfModule>
    RewriteEngine On
    #RewriteRule ^\.well-known\/acme-challenge\/ - [L]
    # Handle Authorization Header
    RewriteCond %{HTTP:Authorization} .
    RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
    # Redirect Trailing Slashes If Not A Folder...
    RewriteCond %{REQUEST_FILENAME} !-d
    RewriteCond %{REQUEST_URI} (.+)/$
    RewriteRule ^ %1 [L,R=301]
    # Send Requests To Front Controller...
    RewriteCond %{REQUEST_FILENAME} !-f
    RewriteRule ^ index.php [L]
</IfModule>
Hi @prince00, and welcome to the LE community forum :slight_smile:
Without an actual domain name, there is little we can do.
Does the domain work via IPv6?
Please follow the recommended installation instructions.
Use snap - not apt
See: Certbot (eff.org)
The tail was too short.
The relevant error message was further up.
You only need to say that once.
[both ways are fine - pick one]
You are using HTTP on Port 443
>curl -k -6  http://\[2a02:4780:1e:b0c5:b9b:15a5:3510:369c\]:443
<html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP r`Preformatted text`eq`Preformatted text`uest was sent to HTTPS port</center>
<hr><center>hcdn</center>
</body>
</html>
And HTTP on Port 80 has an issue
>curl -k -6 http://\[2a02:4780:1e:b0c5:b9b:15a5:3510:369c\]:80
Not really, you're using http:// in the URL and the webserver is actually complaining about that fact. Not the other way around as you're suggesting. That said, HTTPS is giving a non-specific TLS error, so no idea why that's happening.
OK; but using HTTPS on Port 443 yields this:
>curl -k -6  https://\[2a02:4780:1e:b0c5:b9b:15a5:3510:369c\]:443
curl: (35) OpenSSL/1.1.1t: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
Yes, correct, it's broken. I don't know why.
I havn't configure ipv6 even mention ip is not mine. My vps show this 2a02:4780:c:e9e3::1
Then your DNS is probably not configured correctly.
Please supply your information instead others' information.
