our website is blocked by this error and it redirects to the other website because of an ssl error - everything has been working, up until 2 days ago.
I don't see any problems with that site right now. Have you fixed it?
I see HTTP requests to that domain redirecting to HTTPS just fine. And, the cert being used was issued yesterday. You can see your active cert with a site like this SSL Checker
Let us know if you still have problems
Is there an example URL that shows the error? Because I am not going to follow some checkout procedure on an unknown website
Do you configure your own shopping cart / checkout part of the site? Because it looks like a misconfigured system. If someone does that, have you asked them about this?
FWIW, the adambirds site looks like a personal site with someone's CV. That site uses the Cloudflare CDN.
seems to be ok, such a weird thing to happen though!
thank you both for helping!
Caches maybe?
I cleared all the caches out.
If this were a redirect, the address in the browser location bar would change. That isn’t happening.
Instead you’re sharing with us a browser complain that it got a SSL Certificate from a completely different domain than requested.
Usually this happens because both sites are on by the same server OR use the same CDN… AND there is a misconfiguration.
The IP Addresses for both domains are in completely different IP Ranges, so this is not likely due to a server or CDN misconfiguration.
Other possible causes that immediately come to mind are: browser extension malware, compromised servers, and misconfigured/compromised DNS.
Personally- I would do a security audit on the server and your computer, and then check your DNS settings and hosts file to ensure they are correct.
