MacOS 10.13 and cerbot installation errors using HomeBrew
I realize MacOS 10.13 is not supported, but... pretty please.
Can someone help me understands these cerbot install errors when using homebrew:
Upon entering the command "brew install certbot", i get this response -
==> Searching for similarly named formulae...
Error: No similarly named formulae found.
Error: No available formula or cask with the name "certbot".
==> Searching for a previously deleted formula (in the last month)...
Error: No previously deleted formula found.
==> Searching taps on GitHub...
Error: No formulae found in taps.
IF (it is simply not posible to install certbot on MacOS 10.13.6) THEN perhaps some loving soul could inform me so I dont waste time.
ALSO, perhaps there is a manual way to install Lets Encrypt - please let me know.
IF ALL ELSE FAILS, can I simply set up a new maching to generate the Lets Encrypt Certificate and then simply transfer them to my Web Server/Key Chain?
Thank you for any of your thoughts,
Jahfree
Yes. But keep in mind that the lifetime of a certificate is only 90 days, so you need some method of automation on your workflow.
For the macOS stuff - I don't know.
Thank you Nummer378 for your kind reply, I was unaware of the 90 day lifetime. I will use unix.sh script to automate the renewal process.
IF (any member has written such a script) perhaps you could share your algorithm or code with me to run on MacOS. otherwise, I will post my MacOS 13.0 solution for this community.
Peace & Harmony To All
