Help: certbot installation
localhost (i.e. I'm trying to get a certificate working on a local development platform)
certbot --version
OSError: ctypes.util.find_library() did not manage to locate a library called 'augeas'
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/folders/ss/cl31s5td5110tr014jm0hfw80000gn/T/tmp_w27udop/log or re-run Certbot with -v for more details.
My web server is (include version)
Apache2.0 Handler under a Homebrew installation
macOS 11.5.2
N/A
Yes
No
or certbot-auto --version
if you're using Certbot):
Just the problem: I haven't been able to install certbot
The contents of the logfile suggested with the problem command prepended is:
(base) ~ 627 $certbot -v
An unexpected error occurred:
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/folders/ss/cl31s5td5110tr014jm0hfw80000gn/T/tmp4p1mxncu/log or re-run Certbot with -v for more details.
CONTENTS OF LOGFILE:
2021-12-21 20:50:58,533:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/local/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==1.22.0', 'console_scripts', 'certbot')())
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot/main.py", line 19, in main
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot/_internal/main.py", line 1593, in main
plugins = plugins_disco.PluginsRegistry.find_all()
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot/_internal/plugins/disco.py", line 241, in find_all
plugin_ep = cls._load_entry_point(entry_point, plugins, with_prefix=False)
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot/_internal/plugins/disco.py", line 261, in _load_entry_point
plugin_ep = PluginEntryPoint(entry_point, with_prefix)
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot/_internal/plugins/disco.py", line 60, in init
self.plugin_cls: Type[interfaces.Plugin] = entry_point.load()
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/pkg_resources/init.py", line 2465, in load
return self.resolve()
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/pkg_resources/init.py", line 2471, in resolve
module = import(self.module_name, fromlist=['name'], level=0)
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/entrypoint.py", line 3, in
from certbot_apache._internal import configurator
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/configurator.py", line 31, in
from certbot_apache._internal import dualparser
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/dualparser.py", line 4, in
from certbot_apache._internal import augeasparser
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/augeasparser.py", line 74, in
from certbot_apache._internal import parser
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/certbot_apache/_internal/parser.py", line 16, in
from augeas import Augeas
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/augeas/init.py", line 35, in
from augeas.ffi import ffi, lib
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/augeas/ffi.py", line 47, in
lib = ffi.dlopen("augeas")
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/cffi/api.py", line 150, in dlopen
lib, function_cache = _make_ffi_library(self, name, flags)
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/cffi/api.py", line 832, in _make_ffi_library
backendlib = _load_backend_lib(backend, libname, flags)
File "/usr/local/Cellar/certbot/1.22.0/libexec/lib/python3.10/site-packages/cffi/api.py", line 827, in _load_backend_lib
raise OSError(msg)
2021-12-21 20:50:58,533:ERROR:certbot._internal.log:An unexpected error occurred:
2021-12-21 20:50:58,533:ERROR:certbot._internal.log:OSError: ctypes.util.find_library() did not manage to locate a library called 'augeas'
Installation seemed to proceed alright with Homebrew:
(base) ~ 625 $brew install certbot
==> Downloading https://ghcr.io/v2/homebrew/core/augeas/manifests/1.12.0_1
######################################################################## 100.0%
==> Downloading https://ghcr.io/v2/homebrew/core/augeas/blobs/sha256:83b60962039b8d9
==> Downloading from https://pkg-containers.githubusercontent.com/ghcr1/blobs/sha256
==> Downloading https://ghcr.io/v2/homebrew/core/dialog/manifests/1.3-20211214
==> Downloading https://ghcr.io/v2/homebrew/core/dialog/blobs/sha256:7162a6c5041dd65
==> Downloading https://ghcr.io/v2/homebrew/core/certbot/manifests/1.22.0
==> Downloading https://ghcr.io/v2/homebrew/core/certbot/blobs/sha256:93735ba15ab5b9
==> Installing dependencies for certbot: augeas and dialog
==> Installing certbot dependency: augeas
==> Pouring augeas--1.12.0_1.big_sur.bottle.tar.gz
/usr/local/Cellar/augeas/1.12.0_1: 473 files, 3.6MB
==> Installing certbot dependency: dialog
==> Pouring dialog--1.3-20211214.big_sur.bottle.tar.gz
/usr/local/Cellar/dialog/1.3-20211214: 14 files, 925.2KB
==> Pouring certbot--1.22.0.big_sur.bottle.tar.gz
/usr/local/Cellar/certbot/1.22.0: 1,970 files, 19MB
==> Running brew cleanup certbot
Disable this behaviour by setting HOMEBREW_NO_INSTALL_CLEANUP.
Hide these hints with HOMEBREW_NO_ENV_HINTS (see man brew
