LetsEncrypt Cert with EC2 Bitnami
Awesome! Here goes…
/opt/bitnami/apps/wordpress/htdocs/xmlrpc.php
I’m just wondering. Have you tried this link:
https://docs.bitnami.com/aws/how-to/generate-install-lets-encrypt-ssl/
That’s helpful to me when I’m using this service.
Thank you.
Hi Steven!
No, I have not and do not know how it differs from the current script I am running from S3. Do you know it it will accomplish the same means?
Thanks,
sudo ./certbot-auto certonly --webroot -w /opt/bitnami/apps/wordpress/htdocs/ -d baim.tv
Fingers crossed.
Awesome! It worked!!! YEA!!! Thank _az! Now I am attempting to restart the server but cannot
Say the Certificate was successful, but on restart it’s not found :frowning: confused!
Hey what happened? I was typing the commands when you pulled them back.
I gave an incorrect response. If you look at your ln -s commands, you accidentally typo’d .pen instead of .pem. That’s most likely the only issue.
LOL! Awe man, so do I have to run them all again from the beginning?
No, just the two ln -s commands correctly typed should be sufficient, and then restart Bitnami at the end.
For some reason, it says both links already exists…
Ah yeah you’ll need to use ln -sf rather than ln -s, to overwrite them.
You can press the ‘up’ and ‘down’ arrow key in the console to see previous commands and use left/right arrow keys to move around, if you were typing them out by hand every time.
Awesome! Was able to rewrite. Now I am on this step and trying to add this renew code:
Extra if you would like to force https
sudo vim /opt/bitnami/apache2/conf/bitnami/bitnami.conf
Add the text below here:
< VirtualHost default:80 >
DocumentRoot “/opt/bitnami/apache2/htdocs”
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule ^/(.*) https://%{SERVER_NAME}/$1 [R,L]
Before you do that, you may wish to change your WordPress Site URL to https://baim.tv , otherwise WordPress will use the insecure versions of your resources and fail to load them.
https://codex.wordpress.org/Changing_The_Site_URL
Sure thing, but when I log into my WP both are greyed out :frowning:
For others running the bitnami wordpress on amazon LightSail (like this), here is a guide to using letsencrypt-auto : https://medium.com/unicorn-supplies/ssl-for-aws-lightsail-wordpress-8053359a774f
I’d advise against using WP Encrypt plugin as I’ve found it doesn’t renew properly.
Hello,
I am sorry we did not finish this chat, but I am at the final steps and having trouble completing them. Here is where I am:
!Important to renew simply run in your tmp folder.
./certbot-auto renew
RewriteEngine On
When I run this command:
the following screen pops up, but I cannot edit the settings as detailed.
