Lets Encrypt SSL not implementing on autocreated Sub-domains on Multi-Tenant Project
My domain is: https://newcompanies.glazingo.com
My web server is (include version): webmin
The operating system my web server runs on is (include version): Ubuntu 20.04.1
My hosting provider, if applicable, is: AWS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Webmin
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
[https://domain.com]has a Free LetsEncrypt SSL using Virtualmin but when someone register on that website, it automatically create a sub-domain [https://ab.domain.com] and created sub-domain is shown as Non-Secure tag in URL with a invalid certificate.
Is there anyway to implement a Free SSL on sub-domain?
I am still figuring out.
Hi, to get help from a volunteer here you need to explain what you've tried to do in detail, including any errors you've encountered, and things you've tried to do to fix it that didn't work.
Updated
Let's Encrypt certificates do work on subdomains but the system ordering the certificate just has to include those names in the certificate order.
You should perhaps refer to the documentation of your control panel software for automatic https or ask on their support forum: Let's Encrypt auto generate ssl | Virtualmin
Someone here may know virtualmin enough to help but the first place to look is their own support forum and documentation.
I guess, the domain that are automatically created by my user on my webite when they register are NX Domain, those domains are not showing anywhere in virtualmin.
Sounds like you might get more/better help from their support channels.
In theory, sure! However, it all depends on what your software can offer you.
Looking at your situation with randomly added subdomains to your domain, you might benefit from a wildcard certificate. However, while a wildcard for *.example.com would cover e.g. user.example.com, it would not cover another label deeper like www.user.example.com.
