I’ve installed an SSL certificate but it’s not working.
http://admin.oddsclub.eu/
I want to enable SSL certificate on this subdomain with Let’s Encrypt in webmin.
It’s installed successfully but URL not working with https.
webmin (1.930)
Ubuntu Linux 19.04
contabo.net
I can log in to a root shell on my machine (yes or no, or I don’t know):
YES
NO
Hi @parth.parikh
checking your domain via https://check-your-website.server-daten.de/?q=admin.oddsclub.eu you see the problem - Grade Q.
You have already created 4 identical certificates
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let's Encrypt Authority X3
2019-08-29
2019-11-27
admin.oddsclub.eu - 1 entries
duplicate nr. 4
2019-08-29
2019-11-27
duplicate nr. 3
2019-08-29
2019-11-27
duplicate nr. 2
2019-08-29
2019-11-27
duplicate nr. 1
So don't create a new certificate, that will hit the limit.
And your WebMin-Port 10000 uses that certificate:
But your standard port doesn't have a SSL-configuration:
Domainname
Http-Status
redirect
Sec.
G
• http://admin.oddsclub.eu/
167.86.100.89
200
0.096
H
small content:
• https://admin.oddsclub.eu/
167.86.100.89
-4
0.116
W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. The handshake failed due to an unexpected packet format.
• http://admin.oddsclub.eu:443/
167.86.100.89
200
0.087
Q
Visible Content: Login E-Mail Address Password Remember Me Login
Instead, your port 443 sends http content. Checking port 443 with http (instead of https) sends the standard http status 200.
So
use your port 10000 and ignore the error (or)
configure your standard port 443, so that port uses the existing certificate
PS: Result: It's only a webmin configuration problem, not a certificate creation problem.
schoen
August 31, 2019, 2:12am
3
(This would be done by always using :10000 in the URL in your browser, like https://admin.oddsclub.eu:10000/ )
(This would be done by modifying a web server configuration, or a router or firewall configuration if this service is behind a router or firewall that does some kind of port forwarding or port mapping.)
