Let's Encrypt links in CPanel not working
My domains are
hopewwzimbabwe.org
mail.hopewwzimbabwe.org
www.hopewwzimbabwe.org
I simply want to purchase a SSL certificate and install on the website or renew. I got a notification that the Let's Encrpyt one there expires today, 24/12/2022 but can't renew it. RSA, 2,048-bit
Cpane > SSL > Security > INSTALL AND MANAGE SSL FOR YOUR SITE (HTTPS)
A fatal error or timeout occurred while processing this directive. [close]
Template::Exception:
[TYPE]=[undef]
[INFO]=[SSL::installed_hosts(HASH(0x39bbf50)) failed: Unable to retrieve the installed hosts:
[TEXT]=
at cpanel.pl line 1126.
cpanel::cpanel::cptt_exectag("/usr/local/cpanel/base/frontend/paper_lantern/ssl/install.htm"..., 1) called at cpanel.pl line 4647
cpanel::cpanel::run_standard_mode() called at cpanel.pl line 930
cpanel::cpanel::script("cpanel::cpanel", "./frontend/paper_lantern/ssl/install.html.tt") called at cpanel.pl line 326
I don't know
CPanel
Welcome @vmoyana
This looks like a cPanel problem and not related to Let's Encrypt. Should try searching the cPanel forums. Maybe look at this one I found with google
