Issues with certbots ssl certificates
Hi, I'm not great at this so please bear with me. So I'm trying to make ssl certificates and host a MC server off of it. So I use the domain for a website if it is unable to be used for a website and a domain like this then I know my issue, but I believe you can use a subdomain so I don't think it's that. So I tried both my domain (rockymountainhosting.ca) and my subdomain (portal.rockymountainhosting.ca) but both resulted in errors which I could not figure out
certbot certonly -d rockymountainhosting.ca
certbot certonly -d portal.rockymountainhosting.ca
The top is from the domain and the bottom is from the subdomain
I'm running on ubuntu 20.04 if you need any additional info ask and I'll try to find it.
Thank you all in advance
Hello @AXE0928 Welcome to the forum...
We could use some more information to better access the issue(s) and help you find a valid solution.
My domain is: rockymountainhosting.ca www.rockymountainhosting.ca portal.rockymountainhosting.ca
It produced this output: images provided
Hi @AXE0928
that domain is google-hosted - see https://check-your-website.server-daten.de/?q=rockymountainhosting.ca
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
rockymountainhosting.ca A 216.239.32.21 Montreal/Quebec/Canada (CA) - Google LLC Hostname: any-in-2015.1e100.net yes
and a lot of other ip addresses.
So only Google can install a certificate.
And there is already a certificate, https works.
CN=rockymountainhosting.ca
	16.12.2020
	16.03.2021
expires in 82 days	rockymountainhosting.ca - 1 entry
same with the www version.
So you don't need a Letsencrypt certificate. And it may be impossible to create one via http validation, because Google manages that website.
Your subdomain does't have an ip address, so you can't use http validation.
